Thinking about going FI (STS Turbo)
Alright so I am currently running a full bolt 2001 Camaro SS w/ a TR 224/224 cam. I know this isn't the ideal setup for a turbo car. I am just thinking if it would be worth the time and money to swap cams and get rid of the long tube headers. I am looking at some STS Kits and I am wondering if it will work well with my current setup? Or do I need to change it all up to make it perform better? I have heard some people say the TR224 works well and other say LT's are fine to run. I am also lowered 1.5 inches which might be a problem with this kit? Just curious on what I should do? If it's not too much work and I can run it with my current setup, then I might start putting money aside for it. Thanks
even stock you have a good chance of hitting everything, i mocked up the piping from the STS kit on my car and just laughed at how horriblely low it sits. for the money youll put in to a STS kit to make it work right a used or even a new blower is a better option IMO
you need to figure out how much money you wanna spend and double it cause its not cheap going FI(fuel system,trans,rearend,suspension,motor etc)then are you doing ur own work? sts kit is cheap to begin with then you throw alot more into it and you could of bought a front mount...
amen brother, i bought into the STS hype on my LT1, recieved the kit and realized ill never be happy with it so i might as well go front mount. in the end, its going to cost the same so better off doing it right the first time. another thing to consider is your headers, the spool will be horrible with them on the STS kit, but if you got a blower they would make more power than the stock manifolds
Check out the one we built, and the problems we encountered.
http://www.exoticperformanceplus.com...Car.php?car=32 Bob
Mine's finally darn close to sorted out after a year or so of searching for the right recipe and upgrading darn near everything STS sold with it. A real adventure, to say the least.
Bob, that's what makes it so amazing. A stock car with an STS system doesnt do much for me. A car with a custom remote mount turbo system (whether modified sts or not) and all the mods to back it up DOES.
I'm basically just looking at a complete kit with fmic, wastegate, boost controller, wideband, blow off valve, injectors, etc. Looking for a used one around $3k or so. I wouldn't buy a new one since they are pretty expensive. If I could find a complete set for a good price, wouldn't be too bad of an idea I dont think, unless everyone has tons of issues with them...
Yeah I know that's what I am looking at, and those kits are out there...but then I know I still will prolly have to upgrade my clutch an rear, but I could always keep the boost at around 5psi to keep the power down until I have the funds to fully push the car...
I personally believe you would have far fewer problems with a used ProCharger kit than you will experience with a used STS kit. Non working or poorly working oil return pumps are somewhat common with these kits, as is oil pooling in the turbo, and oil return lines popping off the passenger side valve cover.
Many STS kits have been removed out of frustration from their owners, make sure you're ready to deal with this. Bob
