What Plugs And Gap For A D1 Car
Old 07-28-2008, 09:18 AM
JASON11WS6's Avatar
Default What Plugs And Gap For A D1 Car
Just looking to see what kind of plugs and gap all the Procharger guys are running here. I've been waiting to finish a motor build up to put the blower in but I can't wait any longer. I am just gonna toss in the headers, blower and misc bolt ons for now. Since the headers will be off I figured I toss on a set of new wires and plugs. What plug and what gap? This will be on a bolt on car with a low boost D1SC head unit.
Old 07-28-2008, 10:10 AM
EPP
EPP's Avatar
NGK 4177 TR6 set at .035. Bob
Old 07-28-2008, 01:15 PM
JASON11WS6's Avatar
That's kind of what I was thinking. Any changes with more boost? Less gap maybe?
Old 07-28-2008, 04:16 PM
Jontall's Avatar
NGK TR6 set at .035 may blow-out at high RPM. I gap mine at .025, this is also what Kenne Bell recommends. http://www.kennebell.net/techinfo/ge...C_KitParts.pdf
Old 07-29-2008, 04:41 AM
EPP
EPP's Avatar
As you up the boost, you may need to decrease the gap, as has been posted. We haven't seen a need to tighten up the gap much though based on what we have seen on our dyno. Bob
Old 07-29-2008, 09:53 AM
blacksi's Avatar
Is there actually a HP gain from running a wider gap?
Old 07-30-2008, 05:06 AM
EPP
EPP's Avatar
I am no expert on spark plugs, but I have always heard the wider the gap, the larger and higher voltage will be the arc. It takes higher voltage to jump a larger gap. I would always run as large of a gap as you can without having the spark blow out from the boost. Bob
Old 07-30-2008, 06:50 AM
moehorsepower's Avatar
Bob is correct, the larger the gap the more demand on the electrical side of the house, just make sure you have good hot coils and good plug wires...
Old 07-30-2008, 12:39 PM
macleod's Avatar
So if the gap is what decides how hot the spark is then what is the deal with "colder" plugs??
Old 07-31-2008, 10:21 AM
blacksi's Avatar
That all makes sense but what is the advantage of having a larger gap? I wonder if it just burns the fuel better? Does that mean more power though? Is a larger gap then creating more heat causing possible detonation?
Old 07-31-2008, 03:16 PM
Spritle's Avatar
x100000000
Tried and true setup.
Old 08-01-2008, 04:42 PM
ZDOG's Avatar
when you guys say lower the gap with more boost im assuming your going with .35 for 8lbs. now adding 3 or four lbs is that enough to start to worry about a smaller gap?
Old 08-01-2008, 05:01 PM
Disturbed Bird's Avatar
what do you recommend for a F1a? running 12-16lbs
Old 08-12-2008, 09:05 AM
vrybad's Avatar
One step colder will lower combustion chamber temps about 100 Degrees celsius or about 200deg F or so.
The cooler plug transfers more heat to the cooling system.
I spoke to NGK and based on my conversation with them , I went to a TR7 IX, iridium, #3690, which I gapped at .035.
I was running the TR6, but wanted to try a slightly cooler plug.
2002 C5 Z06
Stock engine
APS TT kit
9psi
572rwhp/606rwtq
pump gas, no meth
So far so good, but I've only got about 300 miles on them, and a few 4th gear pulls, but they run great so far.
I pulled one to take a peek, and it looked perfect, no indication that it may be prone to fouling.
Quick Reply: What Plugs And Gap For A D1 Car
