Boosting a 5.3
Boosting a 5.3
hello everyone. first of all i drive a 90' SS454 but i just got a good deal on a 5.3 out of a 99 silverado with the manifolds still bolted up. i was thinking about doing boosting the 5.3 and putting it in my truck. Im really only looking for 450-500 wheel horse. Wat size turbo should i be looking for and how much boost should i need to see my goal? Also what mods to the motor should i need? injectors etc ? .. im new to the ls1 scene and boosting them .. any links or info would be great. not looking to make crazy power. i basically just wanna make turbo and blow off noises on the street lol . thanks
Im running a stock 5.3L shortblock, I used 6L heads to drop the compression. 15psi and it puts around 600hp to the wheels. I use a MPGT-45 turbo and 60psi injectors.
Its been a reliable cheap combo for 2 years now. I seen a few others on here with 5.3s, using T67-T70s and making about the same as me and even more.
so really all i need to do is upgrade the injectors, make sure my fuel system is up to the task and get a good tune on it ? run a t70 at about 10-12psi and i should be good to go ? ill probally go to a ls6 intake just cuz the stock 5.3 one is ugly ..
im in the process of putting my car together. It just a 5.3 with a cam/valvesprings/retainers. ive got a an s475 with a 1.10 a/r on it and im gonna run 12 lbs or so and looking for 550 whp through a 400 and 8.8.
do you have a cam? right around 4k was what i was figuring. im already about 8k dollars into it and got about another 5k dollars to go. still got hotside/coldside and fuel and she'll be running
