I may Know how to fix my "low boost:problems .help me out
Old 08-06-2008, 11:26 AM
SuperZ's Avatar
Default "low boost":problems UPDATE
I have my 17psi spring in there and am only seeing 12psi.I had a crappy boost controller on there on my old setup and now I have no boost controller.Ive been reading that I need to have the bottom port on the WG vac referenced.Can I reference from any vac source?
Old 08-06-2008, 11:38 AM
LS1TECH Sponsor
DrTurbo's Avatar
Yes....pull a vacuum source from the intake side to the bottom port. Also the bottom port opens the gate...top port holds it shut.
Old 08-06-2008, 11:45 AM
SuperZ's Avatar
So I dont connect to a vac source I connect to the pressure side between the turbo and TB?
Old 08-06-2008, 12:36 PM
black98ws6ta's Avatar
Tial reccomends not to use a vac source to the wastegate...just boost only, which means it would have to be before the throttle body. At the same time I have used the intake so the car makes more boost, without any problems.
Bottom port is for a reference, top port is for adding pressure to keep the gate closed, as stated before.
Old 08-06-2008, 01:02 PM
Photochop's Avatar
Per Tial's suggestion on their website (as posted above), I have my bottom port on the WG running to the compressor outlet fitting on the turbo housing. The top port on the WG is vented to atmosphere. Seems to be working fine so far with the .5 bar spring for now and no controller.
Old 08-06-2008, 04:02 PM
veee8's Avatar
How much boost are you seeing with the TiAL .5 bar spring?
Old 08-06-2008, 04:17 PM
SuperZ's Avatar
My S91 does not have a fitting on the compressor what else can I ran it to?
Old 08-06-2008, 04:23 PM
Photochop's Avatar
Not sure yet, still breakin the motor in and savin the cash for the tune. Should have it tuned by the middle of next month and I'll let you know. A little over half throttle it flashed up to 7-8psi on the gauge by accident the other day when I was playin around with it. Hopefully it won't creep much over 8psi...for my trannys sake!
I would think any spot on the charge pipe before it enters your intercooler would be optimum, but it may not matter, probably anywhere before the TB would work. Maybe drill a hole and get a small fitting installed/sealed on the charge pipe and run a 3/8" or so fuel type hose to the WG so it sees actual boost before the TB blade/intake.
Old 08-10-2008, 01:45 PM
SuperZ's Avatar
UPDATE
well I found out my WG cant be blowing open because its not opening at all and still only seeing 12ish psi
any thoughts
Old 08-10-2008, 02:43 PM
alwaysinboost's Avatar
have you done a boost leak teat?
what kind of WG are you running how do you know its not opening at all?
Old 08-10-2008, 02:45 PM
SuperZ's Avatar
its a turbosmart 38mm
I know because we took it off and put a plate over it and the boost didnt change
so would that mean the leak is somewhere between the heads and the turbo?
Old 08-10-2008, 03:00 PM
what kind of setup are you running, is it a rear mount or front mount? the more details the better, pics would help also...
Old 08-10-2008, 05:16 PM
SuperZ's Avatar
Its a truck manifold kit with a S91 and 402 CI motor.Same kit Ive had on the car for 3 years now just up sized the turbo.Im going to check for leaks on with flanges
Old 08-10-2008, 05:50 PM
if you pulled the WG off completely and ran a block off plate and it still made the same boost it could be the turbo, or a huge leak. I'd do a boost leak test first, that would tell you a lot. also check the turbine & comp wheel for any damage.
you could try pulling the boost reference on the WG and S L O W L Y rolling into the throttle to see if it builds boost.
Old 08-10-2008, 08:02 PM
LS1TECH Sponsor
DrTurbo's Avatar
Give us a call tomm. Would like to discuss what all you checked....
Old 08-11-2008, 01:09 AM
SuperZ's Avatar
I found a small crack on the hot parts where a brace is welded that bolts to the block for support.It wasnt super open but is probably half inch long and could feel a steady stream of exhaust coming out at idle.
I put some high temp stuff on it for holes and cracks in exhaust.I dont know if its big enough to hurt that bad its drying now so Ill try it tomarrow..
Old 08-11-2008, 10:14 AM
sevanseriesta's Avatar
is there not enough room to try and weld it shut.... I would recommend that over "some high temp stuff." If it is just silicone then I do not think that it will hold anyways.... What are you using to cover it with?
Old 08-11-2008, 04:11 PM
SuperZ's Avatar
Its not some silicone its a mettalic stuff for exhaust the temp was rated for over 2k degrees.Im going to check it when I get off of work and see if that helped it any.
Quick Reply: I may Know how to fix my "low boost:problems .help me out
