2 Step w/o T-Brake??
Just like the title says, anyone running a 2-step w/o a brake? Do you have it wired to the brake lights or ????
Any other suggestions for the 2 step other than the LPE piece? I don't even know if there's anything else available, it's the only one I know of that can be ordered.
Thought I would update this in case anyone stumbles across it.
I went with the LPE 2 step with the brake lights wired in series with a toggle switch for activation.
First test - it builds 4 psi almost instantly and slowly climbs to 5 after a couple seconds, I might be able to get another pound but I don't plan on waiting 15 seconds for another psi. This is at 3000 rpms. No timing retard, no adjustments in the tune, a/f is about 11.5, methanol just barely starting to spray.
It annihilates the tires on the street, I hope it'll stick on the track!
This is on a 346, APS twins, 3600 PI converter in a 4L80.
