Which WG for S91 turbo???
Just curuious what WG everyone is running with their larger turbos. I have a Tial 44mm and my tuner doesn't think it's going to do the job.
The Tial 44 is a great all around wastegate - how many psi are you looking to run? What is the rest of the setup (motor, tranny wise) I think the 44 would work, but we need more info.
I would also (of course) look at the Turbosmart line of wastegates...the new 50 and 60mm gates ARE AWESOME!
Yeah we have all the gates the make now on the shelf...... We have been using their stuff since 2003....never had a problem with a single one. Only had 1 e-boost go bad in all the ones we have sold. Hard to say that about any company nowadays.
Will any of these bolt up to the same flanges as my tial? My setup is a 408 with s91, 4l80e tranny. Looking to max out around 18 psi but run lower numbers on the street. What is considered low boost? 8lbs??? 10lbs?
Hmm I will check. I don't thing they will, but the Turbosmarts come with the flanges and clamps...so easy to swap.
i removed mine, and used it as a paper weight........
