Thread for oil feed for STS Turbo... NEED HELP NOW, PLEASE
So, I'm working on my STS kit on my T/A.... But i dont have instructions..
I;m trying to find the thread size.. pitch... for the tap for the oil feed line thing...
If someone could just look at their instructions real quick and let me know...
I went to home depot and it doesnt seem to be anything they have so also where to find this tap...
Just a heads up when your drilling into the alum. adapter... drill slowly and use a little lube on the drill bit. Make sure you drill as straight as possible.
If your not carefull I have seen these adapters crack, drill offset, and too far!
Besides that use a good amt. of thread sealer and you'll be set!
The though I.D. 1/8npt to -4 fitting is right at 3/16 of an inch. The stock block off plate for the oil cooler on these motors taps perfectly to 1/8npt thread with out drilling. I've done many of these, I know what I'm talking about. -4 even -3 is plenty of oil line to the turbo, in fact many setup need a 1/16 restrictor put in the line to keep from over oiling the turbo.
