How much can I drop compression by changing head gaskets??
Old Apr 18, 2005 | 09:35 AM
necrocannibal's Avatar
Default How much can I drop compression by changing head gaskets??
I really have been wanting to turbo the 408 but its running around 11:1 compression which I now is too high for boost. I do not want to have to rebuild the motor with lower compression pistons. Can I drop the compression enough to be able to run say 10 lbs of boost?
Old Apr 18, 2005 | 09:38 AM
MECHAM's Avatar
http://rosspistons.com/calculator.php
Old Apr 18, 2005 | 10:10 AM
smokinHawk's Avatar
might want to look at doing a head swap to as being a 11:1 CR with a gasket change will still be somewhat high.
Old Apr 18, 2005 | 12:34 PM
Got Me SOM's Avatar
man if I were you I'd keep that setup, you're gonna have to tear it down to lower the compression.
Old Apr 18, 2005 | 09:09 PM
WS-Sick's Avatar
What's the stock gasket thickness?
Old Apr 18, 2005 | 10:09 PM
69firebird's Avatar
yeah, what is stock gasket thickness, and does anyone know what the 5.3l chamber size is?/
thanks
ed
firebird455@gmail.com
Old Sep 3, 2008 | 09:52 AM
whitelq9ss's Avatar
I have had the same idea of turbo charging my 408 but have the same high ratio 10.9:1. Let me know what you did.
Old Sep 3, 2008 | 11:23 AM
Shawn @ VA Speed's Avatar
why bring back these 3 year old threads?????
Old Sep 5, 2008 | 10:19 PM
98catfish's Avatar
Because if he had asked this ? someone on here would just saylol
