Turbo Technology v.60-1 LS1 Street System
Old 09-19-2008, 12:13 PM
Turbo Tech's Avatar
Default Turbo Technology v.60-1 LS1 Street System
I had a chance to snap a few photos of George and Bob building the 60-1 street system for your 98+ Camaro and Trans Ams. I'm going to hopefully get some more pictures of the build and the install and document them in here. For now here are a few pictures of the parts being built. This kit is very similar to the T76 system as well. The only difference is the intercooler ducting size. (The primaries used to be smaller but we've changed that since the original design so you can upgrade in the future )
Here is the stainless steel manifold sitting in the jig.
This is the two piece v-banded cross over pipe. This cross over is flanged for a 38mm wastegate (Turbonetics or TiAL)
Here is a picture of the 2.5" downpipe (which is identical as the T76 Downpipe (to tell you the truth they are interchangeable); its also upgradable to a 3.00"
This part of the intercooler ducting. Not a lot of excitement here but it gives you an idea of what the parts look like before they show up on your door step.
Couple of things to consider here, this kit is a street system that retains your a/c and your power steering. This kit will make between 400-425RWHP maxed out (60-1). This kit was designed for the stock motor crowd that didn't want anything more. The smaller turbocharger (60-1) gave a fast response (not that the T76 doesn't, but in comparison) and the T76 gives you the ability to make over 600RWHP+. Remember the T76 kit still retains your A/C and power steering as well. If you want more then that its time to step up to a race system like Ryan K and Mighty Mouse
Its hard to build a best of both worlds (street and strip) turbo system but we've done what we can to get you close with our F Body kits
-Nick
Turbo Tech is offline
Old 09-19-2008, 12:35 PM
sevanseriesta's Avatar
Now this is what this forum needed to see..... Thanks TT, hope to see more information from you more often.
sevanseriesta is offline
Old 09-19-2008, 01:04 PM
bluecamaroz28's Avatar
Looking good. Can we see a thread about the race kit build. Would love to see pics of both kits installed on F-body.
bluecamaroz28 is offline
Old 09-19-2008, 01:52 PM
LS1Tech Sponsor
Robin L's Avatar
I ran George's stuff 12 years ago. Always the best stuff out there!
Robin
Robin L is offline
Old 09-19-2008, 02:39 PM
jason02Z's Avatar
looks nice..im running a log kit like this with a 70mm on a stock motor.. works great for me daily driven 10.80's at 125. yeh It is hard to have the best of both.
jason02Z is offline
Old 09-19-2008, 02:47 PM
3.8to6.0's Avatar
subscribing...
3.8to6.0 is offline
Old 09-19-2008, 02:50 PM
Turbo Tech's Avatar
I believe they are out there... I made for Ryan's car, I'll see if I can dig it up...
Old 09-19-2008, 03:23 PM
Turbo Tech's Avatar
Done
https://ls1tech.com/forums/forced-induction/988841-tti-race-system-v-build-up-ryan-k.html
Nick
Old 09-19-2008, 03:46 PM
T61M^3's Avatar
Nick,
Great work, the detail that goes into your work is found few and far between.
Is there any chance a TC66/PT67 etc could be put in place for those who want to max out the factory short block at 500-550whp?
T61M^3 is offline
Old 09-19-2008, 04:14 PM
Turbo Tech's Avatar
Originally Posted by T61M^3
Nick,
It depends how BIG the compressor cover is.. The T76 we use is actually in a 60 cover. We do this to buy our self some room in the engine bay. The 60-1 hifi is designed for those who want no more then 400whp. The T76 has no problems maxing out the stock bottom end
We are going to try something new on this kit as far as the turbo goes. I did some eavesdropping earlier when George and Bob were fabricating..
EDIT: I called Turbonetics and anything in a sixty cover SHOULD fit our systems
Old 09-19-2008, 04:38 PM
Pat-Man's Avatar
T76 kit over here!
Been on the car for years! Still working great!
Pat-Man is offline
Old 09-30-2008, 10:08 AM
pitbull14218's Avatar
This is exactly what i want!!! Then i can show the ricer's how a real stock car with a turbo is!
pitbull14218 is offline
Old 09-30-2008, 01:19 PM
MonkeyBoneSS's Avatar
Pat-Man, what suspension setup are you running? Just curious how the piping is underneath the car. Also could you give us some opinions about the kit over all? Would apprecaite it a lot. Thanks.
MonkeyBoneSS is offline
Old 10-01-2008, 09:22 AM
Pat-Man's Avatar
I'm on stock suspension. I can snap some pics this weekend of the piping under the car. Basically the downpipe runs the same route the stock exhaust does with the exception that there is not a y-pipe anymore. Downpipe runs on the driver's side, bends to the passenger side where the y-pipe merge used to be, and mates to the stock exhaust that is still on the car. It hands just as low as my long tubes and 3" y-pipe that was on my WS6 that I used to have.
Pat-Man is offline
Old 10-01-2008, 09:29 AM
Pat-Man's Avatar
The kit over all is very nice. In my pics it doesn't look quite as nice as a new kit because this car sat for several years only to be started once or twice a month. Even so, there are no leaks or cracks in any of the piping. The cold pipes are all beaded on the ends so you won't have any couplers popping off. Everything is tucked in really well. The only problem I can see with the kit is that my power steering lines are weeping, just due to the turbo being where it is. Of course, most of my hot pipes are not wrapped (just my crossover pipe) and I am not running a turbo blanket (just what seems to be a cheap shield).
Some of these parts might be for sale next year. I'm going to be moving up to a T6 framed turbo (80 or 88) and I don't think one of those will fit where the current T4 T76 sits.
Pat-Man is offline
Old 10-01-2008, 11:44 PM
Turbo Tech's Avatar
I will be posting some new pictures tomorrow... The camera was dead by this afternoon! I charged up the batteries before I left for home today..
Check back tomorrow
Nick
Old 10-02-2008, 09:19 AM
SPRAYED 01's Avatar
What does just the new log cost with a 3inch down pipe?
SPRAYED 01 is offline
Old 10-02-2008, 11:18 AM
Turbo Tech's Avatar
Individual parts are as follows:
T76 manifold $875.00
Crossover pipe $395.00
3.00" downpipe $350.00
I have pictures on the way
Old 10-02-2008, 11:36 AM
Turbo Tech's Avatar
Here are a few photos of the 62-1 placement. We decided to upgrade the turbocharger at the last minute
In the turbocharger pictures you see the sway bar spacers if you look close.
I took a picture of the crossover pipe in the original post and took another one with it half way installed
Next up is the alternator relocation bracket/kit. This can be purchased separately as well for $375.
And thats it for now...
Nick
Old 10-02-2008, 12:09 PM
bad2000z's Avatar
Thanks Nick, I've been eyeing this kit for a while!
bad2000z is offline
Quick Reply: Turbo Technology v.60-1 LS1 Street System
