800+rwhp turbo guys come in
Old 09-23-2008, 10:53 AM
98transguy's Avatar
Default 800+rwhp turbo guys come in
At what rpm are u guys seeing your max hp at?I think i am leaving quite a bit on the table with my baby cam and small heads.My heads and cam are done about 5900 rpms.I think with a larger cam and some bigger heads i could be over 1000rwhp.Current hp is in sig. BTW afr 205 heads , 224/228 on 114 cam vic jr intake
Old 09-23-2008, 10:56 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I'd have to ask Jim but I thought mine was leveling off around 6500 rpms.
Old 09-23-2008, 11:35 AM
NA$TY-TA's Avatar
Id pull to 7K- with my reworked Patriot Heads (2.02/1.57 valves) and baby 224/222 cam.... made power the whole way...
Old 09-23-2008, 02:36 PM
LS1TECH Sponsor
DrTurbo's Avatar
You need to ask yourself, do you really need that much power anyhow?...lol
Old 09-23-2008, 02:47 PM
HUNTER02SS's Avatar
That is good power thru a 4l80e. Just for head comparison's for you, I started out with Dart225 head's out of the box and made 922rwhp at 18psi and then all we did was swap to AFR225 heads and at the same boost i made 1089rwhp. Obviously the AFR heads flow much better and the larger port's!
It was worth the change over for me,plus the thicker deck height. There was other tuning done as well for the better air flow, but pound of boost for pound of boost, the AFR's are much better in my application.
Old 09-23-2008, 04:04 PM
Jake@EPP's Avatar
The biggest thing on your heads Chris is the stainless ex valve, wont last a long time drag racing it at that level.
New heads, solid roller and big stick would surely make some steam
Old 09-23-2008, 04:12 PM
98transguy's Avatar
I am sure the power is plenty enough for me for now.Have to keep my eye on the classifieds over the winter to see if anyone is trying to get rid of their afr 225's(yeah i know not much chance in that).
Old 09-23-2008, 04:13 PM
98transguy's Avatar
oh and Jake since u have drews camera , did u happen to get the dyno video off of it?
Old 09-23-2008, 04:47 PM
Jake@EPP's Avatar
No, i dont mess around with editing. We did some 1/4 mile pulls on it today to see how it would hook the rollers (it didnt). It ran like a 11.3 @ 130 with a 2.0 60ft lol.
We should know tommrow for sure what she really does.
Old 09-23-2008, 05:55 PM
98transguy's Avatar
Sounds like Ted will probably have to ease into the throttle some off the start to give it a chance to hook up.
