Procharger Guys!
The Procharger systems normally have excellent wrap. You have to make sure you do not go too tight or too loose and then you should not have problems with belts. I like to suggest over the 10psi range going up to the 8-rib setup.
We are Procharger direct if anyone needs any price quotes give us a shout.
- Matt
- Matt
The 8 rib system is the way to go to keep from having belt slippage problems, but the six rib kit is still good in the 6 to 7 psi range.
Check out our complete D-1SC price that includes everything you need.
http://www.exoticperformanceplus.com....html?item=798 Bob
Take a look at this CTS-V that we built using an LS2 and an F-1A. Check out the torque on the dyno sheet. http://www.exoticperformanceplus.com...Car.php?car=29
Bob
Might have had some belt slip because of lack of alignment for a few months. The car made great power, just noticed some belt dust. After getting it realigned I've noticed no problems at all. This is an 8-rib SDCE setup making 10 psi. Just goes to show the importance of belt alignment with these procharger systems.
Bob - That CTS-V is freaking wild! I bet that thing is a handful on the street!
I have a SDCE 8 rib with a second tensioner. The only time I've seen belt dust is when pushed the ati tensioner pully down so far the belt was rubbing the stand off nut. here's some pic's...
http://mycarpics.shutterfly.com/63
http://mycarpics.shutterfly.com/62
