Thoughts on why #5 and #7 pistons have chunks missing?
Old 09-27-2008, 06:52 PM
WADDISME's Avatar
Default Thoughts on why #5 and #7 pistons have chunks missing?
Here are the pics from blown motor:
[IMG][/IMG]
[IMG][/IMG]
Could it be from predetonation? It happened at VIR, 71*, water temps were 203* and oil temps were 255*.
Here is my last dyno sheet:
[IMG][/IMG]
I thought it was a pretty conservative tune. Could it still be cracked ring and this is the damage I did on the 3 hr ride home? Thoughts?
Old 09-27-2008, 07:11 PM
DanZ28's Avatar
Hard to tell by the pics, but it does look like detonation. You will know for sure when you pull the pistons out.
Old 09-27-2008, 07:30 PM
CamaroSS19's Avatar
It looks like the car went lean the piston is melted you can se the rings intaked in the first pick. My guess it went lean . Maybe you ran out of fuel pump under load
The dyno graph looks consistent a/f but can figure the # on that I am guessing the line is 12.5 so it looks good on the graph for mid 11's .
But your really testing the stock short block at that power level anyway.
Old 09-27-2008, 07:36 PM
conan's Avatar
They look melted to me too. Detonation usualy looks like you hit the pistion with a ball peen hamer. (little dents every where) I'm preaty good friends with the service manager at our local GM dealer and two weeks ago he took me back in the shop to show me this durmax engine that had a bigger turbo and propane 30#'s of boost on cast pistions... 6 of them were cracked and 4 of them were melted like yours... It made me feel alot better about building a forged moter.
Old 09-27-2008, 09:47 PM
Gingervitis Addict
slow67's Avatar
What do the plugs look like?
Old 09-27-2008, 09:54 PM
MonochromeSS's Avatar
the shape of the missing part in the first pic looks like it melted to me too. 5 looks like it could have some aluminum *****/flecks from detonation on the piston top.
Old 09-27-2008, 11:12 PM
Jake@EPP's Avatar
Definatly detonation, check out the top side rod bearing, it should show abnormal wear in it.
Old 09-28-2008, 09:29 PM
WADDISME's Avatar
They were a little dark and #7 was covered in oil
"Hard to tell by the pics, but it does look like detonation. You will know for sure when you pull the pistons out."
What should I look for with the piston?
My biggest concern is for the new engine and if this was a predetonation issue or an oil starvation issue. From what I gather it is a FI issue and not a road racing issue. It seems $500 for Accusump is pretty cheap insurance for a $9000 motor anyways. Thanks for the input.
Old 09-28-2008, 10:54 PM
Gingervitis Addict
slow67's Avatar
Did the #5 plug look like it had pepper on it up in the electrode?
Old 09-29-2008, 11:20 AM
jeffboy757's Avatar
ooo looks like mine... not running an intercooler and driving it hard melted though it (number 7 btw)
Old 09-29-2008, 12:18 PM
ATVracr's Avatar
Almost looks like a Nitrous piston that has popped the ringland from to much fuel.
