402, 406, 408 what size injectors are you running?
Hey guys what types of injectors and how many # on 402 through 408 with fast 92/92 and big cam 11.5.1 comp. tfs 235 cnc heads. my motor was on the dyno today and I was told that My injectors were at 107% duty cycle at 4000 rpms and 11 degrees of timing. I am new to lsx's but I thought the 42# i had would be fine.
You need to read the posts about this. If you have a 42lb injector at 58 psi that could be a problem. If you have a 42lb injector rated at 43.5 psi, I think that should be good to about 610hp at 80% duty cycle. That would be a 48.4 lb injector @ 58psi. If you have a forced induction car, you would need more injector.
The 42-lb injector should be fine, but if you're at 107% duty cycle at WOT you definitely need bigger injectors. I run the Delphi 42-lb injector with the fuel pressure set to 61 psi at the rail and I see no higher than 77% duty cycle at WOT (it's usually about 73%).
the injectors are the bosch green top 42# are these capable of 640 at the crank or do i need bigger and if they are capable what do i need to do tune wise to get it there. i think they were running at 50 sumthing psi how do i get them to 60 psi and i do have the walbro 255 pump. this is a n/a set up trying to reach 540 at rear wheels.
Stock fuel pressure on an LSx is 58psi. If you are not reaching it, it could be the pump not keeping up with the demand, or there is something wrong with the injectors, causing them to go static, and the pump not keeping up. This could be mechanically with the injectors, or in the tune or ECM.
Have to remember, the injectors are rated @3 bar, the LSx uses a 4 bar pressure, meaning that 42lb injector flows 48.5
