Injector O-ring lube?
Just recieved some 42lb green bosch/ford injectors. o-rings on the fuel rail and manifold side. And no provided lubrication with purchase. regular oil, silicone, none?
those add to the list of stuff to use, do you know what is factory recommended? Does it really matter fuel is acidic? just give me a hammer, j/k
astroglide or ky all the way.
for real, i got that from some installation instructions as an o ring lube and it works great. otherwise ive put regular bearing greese on them in moderation
Thanks guys putting them in today, going to try one with vasoline (what my tuner recomended) and one with dish soap see which one i like.
well, looked at a couple threads before intsall to get some pointers, and I don't want to wash the motor (at 60K) or kill O2's and plugs, going to take PCM to The HPfactory to pre/rough tune and then drive in for a pull. car is sitting fueless, fuel rail and injectors out, waiting for sunrise(some good light) to make sure everything seats right. suppose to snow too!
There in, started it to look for leaks and smoked like a champ. I defintly recomend removing the fuel rail, make sure the injectors are on the rail, and clips are on before you reinstall. little bit of a puzzle to put back in with them on but saves you the heart ache of makeing sure they seat the manifold. lots play if clips aren't in. oh and vasoline worked fine! soap couldn't tell the difference, buddy was lubing them while i put them on, just went with vasoline on the rest.
