150lb bosch high imp injector
we are taking orders for delivery the end of November for Bosch's new 1600cc high impedance fuel injector.. These are not modified in any way and are directly from Bosch, The case is the LS3 style with the uscar plug.. We have the adapters to fit these in a ls2 rail. These fit the ls3,7 and 9 as is.
The price is $149.00 per injector.. We only have 7 sets available.. Any interest please PM
thanks
Jon
thanks
Jon
here are the flow numbers at different pressures.
They are rated at 3 bar
at 4 bar 175lbs
at 5 bar 193lbs
at 6 bar 212lbs
atmospheric pressure is measured in bar. Each bar is 14.5 psi, so 3 bar=43.5 4bar=58 and so on. If you run these at a base pressure of 40 they will flow approx 145lbs of fuel per hour static. If you reference boost at 1 to 1 the added fuel pressure on the inlet side of the injector only equalizes the amount of pressure pushing up on the injector from the manifold side due to the pressure created by the turbo or SC, so after boost the injector is staying the same. A lot of people believe the the added fuel pressure increases the injector flow. This is true only in NA engines or if you reference higher than 1 to 1
they flow 150 at 43.5 in a ls they will be 175 you can also play with the voltage and get these to act a lot bigger. I do not think I can modify these as they are designed for the LPG vehicles (propane powered vehicles) as was the original Bosch 1600.
