Injector plastic ring
When you have your injector out there is a plastic ring just under the o-ring. What is it's purpose? One of mine is cracked and missing a very small piece of that plastic ring. Just wondering if I really have to spend $90 on one injector because of that. Thanks.
I am not saying to do the same thing, cuz I do not want to be responsible for a fire.
All I can tell the bottom plastic piece does is locate the O-ring. The o-ring itself seals to the top plastic piece to keep fuel from leaking out.
Just my $.02
Good luck.
I have had cracked ones and used them they pull off and back on,put a wanted ad for an injector,one would be cheap.I would give you that piece if i had some spares,i just give all my extra injectors away last week
Cool, I'll probrably pin line the crack with some JB on the top side and put it back for now. I'll look for one later. I'm in a hurry replacing the heads on my daily driver and not miss out on work.
LOL... ryarbrough.. I had to look at the link before I knew what the hell you were talking about. I though you were saying I could buy 8 injectors that cheap that would work. I was confused for a minute.
Thanks for the help everyone.
The cracked one isn't going to leak anything, and I have to put my motor back together now to go back and forth to work with. I had a push rod malfunction and had to change heads.
