Are 42's big enough
No you want 60s and if you plan on making more power down the road go 80+lbs it would save you time and money down the road. Im on my tried set of injectors lol
And the mods will be moving this thread for sure lol
Def not enough injector. Go with 60's at least like tomz28 said. I havn't bought mine yet, but I am torn between 60's or 80's. Planning on 550 to 600 RWHP, so 60's may be on the edge. You can always tune down on a bigger injector to an extent. You can't tune up on an injector thats maxxed out though. Just keep that in mind.
I have some for sale in my sig, they are low impedance though so you will need a driver. There are advantages of having low impedance injectors & if you ever wanna go really big you will most likely be buying low impedance injectors. The reason bigger injectors are usually low impedance is that they can open a lot faster.
Check out this link, its specifically refers to 60# injectors, & mine are cleaned & flow checked.
http://www.acceleronics.com/faq.htm#1
Lol, yeah we all start somewhere, live & learn. Check out how far I pushed my 57's, by accident of course. Fortunately I realized that my car should not accelerate that fast & let out. Its still living with the motor GM blessed it with, this thing must have nine lives lol!
Check out the 3rd column down in blue.
I heard something like since they are ford injectors, they are rated with a lower fuel pressure. And since the Fbody fuel pressure is higher that makes the injectors flow more...is this making any sense? I was told that the injector could be used safely up to 500 hp. If they are the ford injectors?
Im gonna run 42lb injectors on my N/A 396 LT motor Itll be around 550 at the flywheel & i have an adjustable regulator A turbo motor with the same power needs 52lb Theres a calculator thats got boosted or n/a & supercharged type choices Free download I dunno how to post a link lol Its virtual engine 2000 On an LT1 car ford injectors flow 5% more because of fuel pressure
