Fuel system info needed
I'm needing some fuel system info for my Mustang LS Conversion (5.3 and 4L60E). Stock motor, maybe with a cam for now, probably will get a shot of nitrous down the road . I always like to do it right the first time so I don't end up doing it again down the road. From my build thread:
Picked up a cheap LS1 Intake
Any particular aftermarket fuel rails better than the rest? I see them on Ebay all day for less than $100/set. Was curious if those were any good or not? I'll be running them with the rest of the fuel system I already have most of.
Magnafuel MP-4303 pump and Magnafuel dual fuel pump relay setup.
Filters
Aeromotive (from Fast system) 13101 regulator
Aeromotive (from Fast system) Y-Block
Also already has in tank pick-up with AN fittings, and braided line all the way to the motor and back to the tank.
Also curious how everyone is hooking their aftermarket fuel rails up. With the Ford 5.0L, it was setup with a braided line from tank to Y-block, where it split and sent a line to the rear of each fuel rail. Then a line came off of each rail into the two sides of the regulator, with a single return line going back to the tank.
Is this the recommended setup for a LS motor? Thanks in advance for ant help you can provide.
Filters
do you have a flow curve on that pump? (data)
talk to Lonnies or Nasty N8 or both for fuel rail. Either can set you up with all the -AN lines & braided tubing you will need.
as far as injectors some 36# on that size motor with a wet nitrous shot should do you fine. you could go 42# but what power are you looking at making and what all is done to the 5.3L ?
mine is a single feed to the drivers side front of the rail, loop to other rail in back , from passenger rail to fpr, return out of fpr.
Found this on Yellow Bullet
Independent test of Magnafuel MP-4303
100 micron sock inlet
-10 feed, -8 return
13.8v dc
158.4gph @ 40psi
148.2gph @ 50psi
137.4gph @ 60psi
126.0gph @ 70psi
114.0gph @ 80psi
I have no idea what power I'm looking at making. I was putting a new motor in, and was doing a tubular k-member too, so what better time to make the jump to LS right? It's purely just an extra car. Not a daily driver, but I do drive it on the street a lot. Plan for now is to get the 5.3 put in, along with maybe a cam. Get it back to where I can drive it, and add to it as I go. I'm switching from the truck intake to a LS1 intake I picked up cheap. I'm need fuel rails anyway, so was just checking to make sure the $100 ones on EBAY aren't junk before I buy them.
Is that the most common setup?
-10 feed, -8 return
13.8v dc
158.4gph @ 40psi
148.2gph @ 50psi
137.4gph @ 60psi
126.0gph @ 70psi
114.0gph @ 80psi
With all the parts shown above that I already have, except for fuel rails that I need to buy, this is how I'm planning on running my fuel system. Anyone else running it this way? I know some say it is overkill to go parallel, but I already have the parts, and would never need to redo it. Comments? Suggestions?
Those rails are junk I have seen them split just putting the fittings in the end. I would not trust my fuel to that. That pump is also entire over kill and will create a ton of heat cycling back to the tank several gallons a minute. I would really tame it down for the relatively stock motor all you need is a cheap Walbro and a single Universal swap kit we offer for LS motors in other cars. I could set you up with an entire system for over 600whp for about $500 setting that pump and parts up will be thousands before it is done.
