Aeromotive FPR plumbing
1994 Camaro with LQ4 swap, LS1 intake and aftermarket fuel rails.
Guy who built the car installed an Aeromotive FPR and AN lines all the way to the tank. Take a look at this picture and confirm that this isn't right.
The return AN line to the tank is just pushed onto a barb fitting. Also, the vacuum reference line is not connected.
Can anyone ID the FPR? Need a model number so I can figure out what fittings I need to fix this.
Thanks.
Thanks.
Doesnt look like pushloc, just standard braided that someone cheaped out on a fitting and simply clamped it
Cant see the rail ports in your pic, but if it runs at all its likely plumbed properly
Pump feeds directly to a rail, then crossover, side port on the FPR is on the return side of the rail. Return line to the tank is on the bottom. Vacuum port is left open for N/A, plumbed to the intake for boosted applications to raise the fuel pressure as boost increases
Id fork over the $5 for a proper hose end but a clamp on the return line wont hurt anything besides your eyesight
If I can just put a fuel injection clamp on the braided line I'll be happy, as long as that line doesn't pop off the regulator I don't care what it looks like.
I would like to get that intake setup this spring... What rails are you running?
I would like to set my fuel system up just like this and switch it over to the new setup when i'm ready... I can't see it in the pic but there is another line that runs across the back of the intake right?
Thanks
Thanks
Well that return line is pretty tight on the fitting. I did hook up the vacuum fitting on the FPR, guess what? I can now rev the car without it choking and dieing. yay!
Thanks.
Thanks.
