Filter with E85
Old 03-26-2013, 08:19 PM
RedRocketZ28's Avatar
Default Filter with E85
I am getting ready to upgrade my fuel system with -8 feed, rails, and 127# Bosch injectors. I have been trying to decide what filter I need to run. I have read all over the place where people say it HAS to be a mesh screen filter. A select few seem to be running any old filter with their setups. Right now I am on the stock style filter and have noticed no problems. Is there a reason why I need to spend $80 on a fuel filter? Would any inline 10 micron filter work for me as long as the element is changed out every few thousand miles? I don't want to jeopardize possibly ruining $900 injectors with a filter that wont catch everything, or one that may breakdown.
Any help and suggestions is greatly appreciated.
Old 03-26-2013, 09:29 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
Paper/cellulose type elements can deteriorate from alcohol.
Use mesh stainless or a fiberglass element 10 micron or finer.
A restricted injector will only melt a piston, so $80 seems like cheap insurance.
I have these in stock if interested.
Old 03-26-2013, 10:21 PM
Thanks Lonnie. Is it best to give you a call?
Old 03-27-2013, 11:57 AM
slowride's Avatar
Fuellab with a fiberglass filter/element. Carbon inpregnated PTFE lines.
Old 03-27-2013, 12:27 PM
So I can pick up the 3 inch element -8 filter, then get one of these to throw in it?
http://fuelab.com/virtuemart/fuel-fi...filter-element
Old 03-27-2013, 01:41 PM
slowride's Avatar
You can buy it that way. Get the longer one for extended service life if you can fit it though. Talk to your turbo guy
Old 03-27-2013, 08:09 PM
LS1TECH Sponsor
Call me, the Fuelab filters are the ones I stock.
Old 03-31-2013, 11:35 PM
I8UR4RD's Avatar
I will be running the 82832 Fuel Lab
6 micron
8AN Inlet/Outlet
Fiberglass Element.
Some people are changing the filter after the first few tanks of e85 since supposedly it starts to break down any crap that was already in there.
I have seen several threads showing people cutting into paper filters they used for years around 3000-4000 miles that looked like new. I say better safe than sorry though, let them risk it to find out. Fact is its corrosive, and I want something better than paper as a barrier between harmful contaminants and my high dollar fuel system. As lonnie said, cheap insurance.
Quick Reply: Filter with E85
