FAST rails.. no lines with kit what to use???
Old 04-14-2013, 04:28 PM
2000ws6transam's Avatar
Default FAST rails.. no lines with kit what to use???
got the 146032 kit and it comes with not all the things i need to hook it up WTF FAST!! (about as annoying as the 102 without gaskets included)!!! Anyway i needed to know where i can find the cross over fuel line, fuel line fitting to the stock line up to the rail and the block off for the end of the rail. Do i need any type of regulator? i am assuming the racetronics is regulated in the tank and should be fine. thanks!
Old 04-14-2013, 05:09 PM
djfury05's Avatar
Are all the fittings that came with the kit -8an? Or is one the fittings an -8an to -6an reducer union and the other 3 all -8an unions?
Old 04-14-2013, 06:02 PM
2 -6an and 2 -8an
Old 04-14-2013, 06:19 PM
djfury05's Avatar
Here is all the fittings you'd need.
-6an hose end fitting for the feedline
http://www.jegs.com/i/JEGS-Performan...rentProductId=
-8an cap for the end of the fuel rails
(2 of these) -8an 90* hose end fittings for the crossover
-6an 90* hose end fitting for the feed line to the rails
Quick disconnect for hardline to AN conversion
http://www.jegs.com/i/Russell/799/644123/10002/-1
Do some searching online for the -6an and -8an hose. You will need probably 18" of both to be on the safe side. I will check to see if I have any left that I could make a deal on.
Old 04-16-2013, 01:37 PM
Nasty N8's Avatar
http://www.nastyperformance.com/shop...l-install-kit/
Old 04-20-2013, 09:51 PM
Super Hulk Smash
JakeFusion's Avatar
http://www.hinsonsupercars.com/p-117...-line-kit.aspx
The Torrent Kits are nice. I think they may be discontinued... Hinson still has some.
Old 04-23-2013, 07:27 PM
i see all of these kits but the aeromotive and the professional products is the only one i have seen with the male end to go into the stock fuel line.. or am i crazy?
Old 04-23-2013, 07:33 PM
djfury05's Avatar
That Nasty Performance kit has it all.. the fitting your talking about is the one in the upper left hand corner.. It has a plastic disconnect fitting on one end to slip over the stock metal fuel line.
Old 04-23-2013, 10:50 PM
thanks for your help, just ordered all the stuff you had listed from jegs and some jegs braided line 3' of -6 and -8
Old 05-06-2013, 07:15 PM
well iwent to hook it up today and this fitting http://www.jegs.com/i/Russell/799/644123/10002/-1 doesnt work with what i have...
http://www.jegs.com/i/JEGS-Performan...03120/10002/-1
is what i need but with a 90 degree elbow on it any ideas?? i cant seem to find one!
Old 05-06-2013, 08:17 PM
djfury05's Avatar
You sure your hooking it up correctly? The little U-shaped part goes over the stock metal feed line first underneath the little bulge portion of the hardline. Then you put the rest of the fitting over the stock metal hardline and slide it til its butted up to the bulge on the metal feed line and then you screw in the U-shaped portion into the fitting until it is tight.
After that you have your 6an hose fitting that connects to the Russel adapter fitting.
Take a picture with what your working with if I am misunderstanding what your trying to do.
Old 05-07-2013, 01:00 AM
here is a pic
Attached Thumbnails FAST rails.. no lines with kit what to use???-0504134128.jpg
Old 05-07-2013, 11:03 AM
djfury05's Avatar
Lol... you have to remove that portion also.. there is another plastic disconnect at the bottom where it meets the actual METAL hardline. That is where the Russell fitting goes once you remove the portion in your hand. I didn't get you the wrong parts trust me.
Quick Reply: FAST rails.. no lines with kit what to use???
