E85 and ~1000whp
Old 12-07-2013, 08:55 PM
fly boy_1's Avatar
Default E85 and ~1000whp
I'm doing a turbo 5.3 in my car and I'm upgrading the fueling to be overkill. Currently I already have waiting to install, a Aeromotive stealth 340 pump and the appropriate racetronix hotwire kit for that pump, an aeromotive regulator, and I'm thinking I'm gonna need to go to a 8an feed and 6an return.
I'll probably have to add a second 340 pump and hotwire harness, right? Any links to fuel line stuff I'll need or any other misc stuff I'll need? Any suggestions for big injectors? I know for e85 I need special fuel lines, would I need different lines in tank for the pumps also?
Old 12-08-2013, 08:10 PM
703 CAMAROSS's Avatar
Yeah two 340 pumps for sure 8AN feed and 6AN return. Btw the racetronix pumps are the same thing as the aeromotive and their like 60 cheaper each if I remember right. I just ordered a fuel system for the same goals two days ago. You can get everything you need from racetronix I think I spent around 1100 without fuel rails and injectors. They make a universal dual relay harness that works for dual pumps and you can piece it all together online. They have top notch customer service Btw.
Old 12-08-2013, 10:23 PM
fly boy_1's Avatar
Did you get special lines for using e85? I have their single harness for the 340, is the dual harness just two of those?
Old 12-09-2013, 09:13 AM
Yes they sell the line you need. It's Teflon coated. Not sure as iv never had a single harness. You can see the picture of it on their website. You completely bypass all the stock wiring and all you use is the pcm trigger wire to trigger the relays. Or you can use the pcm to trigger one relay and a hobs switch to trigger the other.
Old 12-09-2013, 09:39 AM
I need a gauge for that
Atomic's Avatar
Hope you have huge injectors...
Old 12-09-2013, 10:10 AM
fly boy_1's Avatar
From what I've read something around 160's right? I'll have to check out the dual harness thanks for the info.
Old 12-09-2013, 10:16 AM
Atomic's Avatar
Its pretty simple to figure out exactly what you need, https://ls1tech.com/forums/fueling-i...pump-flow.html
Old 12-09-2013, 03:28 PM
LS1RedZ's Avatar
So has anybody actually pushed these 340s that high yet? I'm having pressure issues right now and Im not sure what is going on.
Old 12-11-2013, 08:35 AM
2muchboostNY's Avatar
A few guys I know have and a few have had issues well below these numbers. It seems they are hit or miss. Theres a few google finds that show these have been pushed into the high numbers and some fail very early on.
Quick Reply: E85 and ~1000whp
