Who make the best quick disconnect?
http://www.jegs.com/webapp/wcs/store...ick+disconnect
Heard bad things
http://www.summitracing.com/parts/ear-991966erl
Don't know about this one
Where are you finding the Aeromotive?
Heard bad things
I didn't realize the issues these adapters caused people when I bought mine and simply stumbled upon a good one. I couldn't find what I was looking for in the summit catalogue so I called them and they sent me a fitting that adapts my 3/8 quick connect line to -8, it saddles the ridge on the line and then screws together and can not come off like the ones linked above. I can't tell you the part number or manufacturer but I can tell you that a better fitting is available at summit. I will check my build thread and see if there is a picture of it
https://ls1tech.com/forums/nitrous-o...ous-build.html
Zoom in on the fourth picture in the first page and you can see the fitting on my stock line. It unscrews into two pieces, the lower piece saddles the line and then you screw the top piece on. Works perfectly and no chance of blowing off
This is the style Russell fitting to use.
The U shaped part threads into the back of the fitting forming a positive lock, locking the fitting on the line.
These are available from Summit in various sizes, blue or black color.
Use key words "Russell Push-on EFI Fittings".
http://www.summitracing.com/search?S...EFI%20Fittings
