Replacement alternative to feed and return plastic lines
Need some help, i am in the process of replacing my stock fuel pump with a racetronix and am a little skeptical of reusing the stock plastic hoses. I thought i heard a crack when removing the hose off the fuel tank. Cant see anything. Since gm discontinued the factory ones and i do not have the time to drop this tank again, I'm looking for a permanent solution. I modified a fuel assembly once on a neon and did a return line. I plan on passing this car onto my son so looking for a permanent fix. I see some have gone an fittings to a metal line than I'm assuming high pressure fuel lines. I know i cam clamp the one side on the fuel filter. Just looking to see how others have gone about this
These are the internal nylon lines for the pump.
http://www.racetronix.biz/items.asp?...atus=0&Tp=&Bc=
Lonnies Performance
Lonnie is a sponser here on LS1 tech. Lonnie works with stock & custom fuel systems for f body cars. He can help you with your fuel lines. Lonnies performance.com. He is the. most knowledgeable person of I have ever spoke with on LS1 fuel systems.
Thanks guys, but im looking for the external lines on the outside of the tank. I spoke to lonnies, got a new venturi feed line from him but he did not really have any suggestions
Dorman makes alot of fuel line repair parts, for both nylon and steel line, usually available from jobber parts houses that supply repair shops
http://www.dormanproducts.com/gsearc...el+line+repair
we have a race car builder locally here that carries 20ft lengths of straight fuel line too, you may ask around your area to find a similar source
I finally located a place in arizona, i need 6 1/2 ft of house and the machine on the 6an swivel ends. I got 3 3/8 quick connects and one 5/16 ill post pics once they arrive and are installed.
