A1000
Old 07-25-2016, 07:04 PM
Mustang Hat'r 2's Avatar
Default A1000
I will be running a stock L33 or cam only with headers. I will be going twin turbo at some point. If I run the A1000 with matching regulator will I burn the pump up? I could have sworn I read some where that this would happen.
If this isn't OK can some one recommend a decent pump for a fuel cell then I can just mate it to a vette filter for a temporary.
Thanks
Jay
Old 07-26-2016, 07:16 AM
Restricted User
JoeNova's Avatar
Please don't use an A1000. 15 years ago they were decent pumps. Now you can get OEM pumps that produce the flow you need for a quarter of the price that are ten times as reliable.
The new AEM 380 lph pump is cheap and has been showing huge promise.
Old 07-26-2016, 11:33 AM
Will the AEM work with a fuel cell?
I will be 320-350 at the wheels to start then 600-700 with a twin set up.
Thanks
Jay
Old 07-26-2016, 11:51 AM
Restricted User
JoeNova's Avatar
The AEM should support ~750-800 wheel. They flow very well at higher pressures, better than most other pumps including the Walbro 450.
And yes they work with a cell, they are external.
Old 07-26-2016, 12:12 PM
Thank you for the info. Do you have a regulator that you could also recommend?
Old 07-26-2016, 12:18 PM
Restricted User
JoeNova's Avatar
I use the Aeromotive 13129 with a lot of luck.
Old 07-28-2016, 03:33 PM
.boB's Avatar
I'v been using an A100 for about 12 years or so. Big and noisy. Not particularly cheap. And I'v gone through 3-4 of them. But I just run it off straight 12v, without a controller. In theory, a big electric pump will last longer with a controller.
I'v been looking at the new Holley pump as a replacement. Supposedly a better pump for less money. And I can use my MegaSquirt ECU to control it.
Old 07-29-2016, 08:56 AM
Restricted User
JoeNova's Avatar
Are you talking the new Holley dual pumps?
Its literally a pair of OEM Walbro pumps in a Holley housing. Nothing more. People have even cracked it open and looked up the pump part numbers to see that they're just $75 Walbros.
Old 07-29-2016, 07:57 PM
Taxman20's Avatar
A1000 pushes a crap ton more flow than you need for 3-400 rwhp. Its going to return a ton of fuel and then heat up the gas in the cell. They also don't like to be restricted too much. I burned mine up in about 100 street miles. Even Aeromotive will tell you to go a different route.
Old 07-30-2016, 06:44 AM
I knew I read that some where that it was a bad idea.
Thank you
Old 08-06-2016, 07:27 PM
.boB's Avatar
I know that Holley electric in tank pumps have been made by Walbro for a long time. It wouldn't surprise me that the new pumps are also made by Walbro.
Is that good? Is that bad? IDK.
Quick Reply: A1000
