Fuel Rails and Fittings
Old 11-09-2005, 02:06 PM
DanO's Avatar
Default Fuel Rails and Fittings
I am looking to purchase the Fast Fuel rails. I was wondering if anyone knew what thread the rails have on them? 3/8"-NPT???
Also, Does anyone know what Aeroquip part number is needed for adapting to the stock fuel hard lines? (somthing that has a -6 Female end on one side)
Im about to go get all my fittings and those are the only two i am unsure of
Old 11-09-2005, 02:09 PM
Brandon Boomhauer's Avatar
look for Parbreak's thread in this forum...
should be on the first page if not the 2nd.
russel is the only fitting company that i've seen to adapt to stock line...
Old 11-09-2005, 02:20 PM
99blancoSS's Avatar
Ask Nate at Nasty Performance, his ls1 kit uses it.
Old 11-09-2005, 02:29 PM
thats where i got my parts....
Old 11-09-2005, 02:34 PM
99blancoSS's Avatar
I went with his fuel rails and kit for the ls1, very good quality. Very happy with it.
Old 11-09-2005, 03:16 PM
DanO's Avatar
Well.. i work at Eaton (owner of Aeroquip) and i can get a few fittings for free, i didnt see anything similar to the russel fitting... hmm. Looks like i may have to pay for it.
Old 11-09-2005, 03:39 PM
Welllll i could use some fittings
but the only thing i've found is the russel fitting that Nasty uses, and its the same as posted in that thread.
But, those fittings are rarely listed through various places, its a female 3/8hardline to -6an i believe
check with aeroquip to see if they have it, but i doubt they do. Nasty is a fan of aeroquip fittings, and his kit includes all aeroquip except for that fitting.
Old 11-09-2005, 11:43 PM
99blancoSS's Avatar
I think there were 3 different companys in the kit can't remember, but the connection to the factory line was sweet, he's the only using it from what I've seen and only one mfg'er makes it from what we could find when looking for it.
Old 11-10-2005, 05:42 AM
samdogmx's Avatar
i just picked up a set of FAST rails, i can tell you they have 8-an threads in the ends
Old 11-10-2005, 07:21 AM
DanO's Avatar
That is with the fittings, the actual rail is tapped for 3/8-NPT, then a 3/8 to -8AN fitting is on the end.
Old 11-10-2005, 07:59 PM
samdogmx's Avatar
no they are tapped 8-an, Pipe threads are tapered & these are definatly not tapered. i can screw both ends of an 8-an unioin into the rail.
Old 11-12-2005, 11:22 AM
Nasty N8's Avatar
Awe man FAST rails? Why we just ran a sale on our rails. Ours are 3/8" pipe I do not know what FAST uses maybe O'ringed -8. As far as the Russell fitting they are the only ones that make that style fitting everyting else I try and use Aeroquip.
Nate
Old 11-12-2005, 01:19 PM
DanO's Avatar
you still running the sale on your rails, nate?
Old 11-13-2005, 02:26 AM
GTS346's Avatar
Earls make a hard tube adaptor as well without the need to flare the tube, I have there 2003 catalogue and its listed, just purchased 3 the other week.
p/n 165006ERL
http://holley.com/products.asp?product=165006ERL
