Fast fuel rail pics.
Old 01-28-2006, 02:47 AM
Stangkilr's Avatar
Default Fast fuel rail pics.
I need some pics of the fast fuel rails installed. I cant figure these things out!
Old 01-28-2006, 02:48 AM
Brandon Boomhauer's Avatar
whats the problem?
Old 01-28-2006, 08:33 AM
Coal Mining Director
onfire's Avatar
Try this
Old 01-28-2006, 04:54 PM
Stangkilr's Avatar
Originally Posted by Brandon
whats the problem?
Cant figure out how to hook it up lol.
Old 01-28-2006, 05:18 PM
99whitews6's Avatar
Heck, the picture should explain how they go on.
My question is why do they give you two different size end fittings? And what are the part numbers for the pieces needed to finish the fuel crossover, put a pressure gauge on another end, and connect the last end to the stock fuel input?
Old 01-28-2006, 06:10 PM
Originally Posted by onfire
Try this
holy fitting nightmare.
why not just take the 8an off the 90s on the backside of the rails to the Y instead ofa ll the fittings?
Old 01-28-2006, 08:00 PM
onfire's Avatar
You could, but I wanted the y on top of the manifold.
Old 01-29-2006, 08:06 AM
SRZ
SRZ's Avatar
They make any rails like that for us LT1 owners?
Old 01-30-2006, 12:56 PM
Nasty N8's Avatar
We have all the fittings needed to finish your install and all the addapters for fuel gauges and nitrous lines.
Sorry no LT1 rails we have modified the stockers to accept AN fittings.
Nate
Old 02-12-2006, 01:02 AM
00MysticZ's Avatar
anyone else have more pics of this set up mabey in a diff way i like the looks of this one but just want to see the diff ways to hook it up
Old 02-12-2006, 08:56 AM
onfire's Avatar
https://ls1tech.com/forums/fueling-injection/451530-picture-harris-speed-works-teflon-fuel-lines-fast-rails-weldon-regulator-w-n.html
Old 02-13-2006, 06:47 AM
RedWS6 00's Avatar
I got some photos of my Fast Rails on the Fast intake before I put it in the car. Hope these help your install. I got the brackets anodized blue, they were silver in the kit. Since these photos I have joined the rails together at the front too.
Attached Thumbnails Fast fuel rail pics.-intake_fast_lsx_and-_fuel_rails_5.jpg   Fast fuel rail pics.-intake_lsx_off_b.jpg   Fast fuel rail pics.-intake_fast_lsx_and-_fuel_rails_3.jpg
Old 02-13-2006, 08:20 AM
onfire's Avatar
For 95% of the people installing rails, that's the best and cleanest method to use.
Old 02-14-2006, 01:47 AM
obZidian's Avatar
did you guys tape of your fittings to the rails? thinking about doing it and i cant remember if it was recommended or not. I think it would hurt.
I wanted to tape of the fittings, the balck ones that came with the rails, to well, the rails. Than tape of the npt sides of the fittings as well.
Old 02-14-2006, 02:15 AM
RedWS6 00's Avatar
What tape are you thinking of PTFE / Teflon tape? are you thinking of adding it to the thred? make sure its safe for fuel, usualy plumbing tape works fine for water buy it may break down with fuel, I'm not sure though.
On thing I know is I dind't put any tape on mine and they are totaly leak free.
Old 02-14-2006, 10:49 AM
slt200mph's Avatar
This is a much cleaner looking configuration..I am getting ready to do this install and this will be the way I do mine..I beleive that you do not need to use tape on these fittings..I have always run mine without tape..
Old 02-14-2006, 10:59 AM
Nasty N8's Avatar
Do not use tape on -AN fittings it is not needed. Only need tape on pipe thread fittings.
Nate
Old 02-15-2006, 10:45 PM
obZidian's Avatar
thanks, guys, what about mounting the throttle cabel bracket with the fat rails. Im trying to get mine on and it is hitting the fast rails!! Well, the front rail fitting is in the way...
Should i just go ahead and force it in there (hey, thats wat she said!!) or machine it a bit?
EDIT:
Ok, i found these black washers with my kit and used those to space out the passenger side rails a bit. I noticd that they seem to not be straight up, but leaning in toward each other. So i spaced out the pass. rail and wappap!! IT worked..the bracket goes on with no problem.
However, now i have an issue where the pass. rail is not as "in" as the driver. I guess i'll just find some washers and space out the driver side.
DId anyone have a similar issue and did you also have only two black washers with your hardware kit?
Old 02-16-2006, 02:32 PM
DeltaT's Avatar
When you do the AN conversion you need to machine for the O-ring fittings. No tape needed.
Jim
Old 02-17-2006, 11:28 AM
BBBBadSS's Avatar
That is how im running my Fast rails. Someday im adding a TNT F1 kit, could i run the fuel feed line off the passenger side rail where it is pluged?
Quick Reply: Fast fuel rail pics.
