60# injectors
Old 05-09-2007, 03:33 PM
JASON11WS6's Avatar
Default 60# injectors
When do 60# injectors die horsepower wise? Generally speaking of coarse.
Old 05-09-2007, 03:52 PM
Silver02Z28's Avatar
Here's the formula to use.
fuel requirement lb/hr = (HP * BSFC) / (num injectors * duty cycle)
Use BSFC = .5 for NA, .6 for forced induction
Use 80% (.8) for duty cycle.
To solve for hp re-arrange the equation to:
hp = (lb/hr * num cyl * duty cycle)/(BSFC)
Forced induction = 640 hp
NA = 768 hp
Someone check my math
Old 05-09-2007, 05:45 PM
Nasty N8's Avatar
Depends on the tune and the fuel system behind them. I have seen over 850rwhp with 60# injectors.
Nate
Old 05-09-2007, 05:47 PM
Nate
They'll go higher, but not at 80% duty cycle.
Old 05-10-2007, 08:00 AM
Frost's Avatar
They'll do over the 640hp-FI you listed at under 80%...
Old 05-10-2007, 08:35 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
These numbers are for flywheel HP correct?
Old 05-10-2007, 10:31 AM
Todd157k's Avatar
Save the math for the computer..
File Type: zip
Old 05-11-2007, 07:18 AM
Frost's Avatar
MIGHTYMOUSE made over 850RWHP with 60s and meth.
I have had my setup up to 18.5psi on good gas and meth, and that HAS to be in the 700s rwhp-wise and mine had room to go.
Old 05-11-2007, 10:23 AM
JASON11WS6's Avatar
Thanks guys, I was planning on running a D1sc with the intent on maxing it out down the road. I was also mulling over the whole E-85 idea as well. I know you need a bigger fuel system as the E-85 requires more fuel. I'll probably end up with a dual racetronix set up from Nasty so I know the pump will be plenty goood. Would my 60# Motrons hold up to 700rwhp with E-85???
Old 05-12-2007, 11:08 PM
eb02z06's Avatar
They were long dead at 885, barely made it to 800, this on a F1R thorugh a auto though.
Old 05-14-2007, 09:54 AM
NemeSS's Avatar
and this was using a hi flow return fuel system with a rising rate 1:1
regulator?
what was base fuel pressure set at?
stock 58psi?
Old 05-14-2007, 10:25 AM
Frost's Avatar
I don't know what his base pressure was but was likely in the 60s somewhere.
Old 05-14-2007, 03:01 PM
From the attached spreadsheet.
Find Max HP of Injector
Fuel Injector LB/HR 60
Number of Cylinders 8
Duty Cycle Desired 80%
BSFC (.5 for NA, .6 for FI) 0.6
HP of Injector 640
Meth changes the equation, and a RRFPR helps.
Theory (math) and reality don't always mesh. I'm sure they are being used in much higher HP applications. This equation is a good place to start. If you can get more out of them, nothing wrong with that.
Old 05-14-2007, 03:28 PM
Wait, my bad.
Aren't they rated at 3 bar?
In that case, they are more like 70 lb/hr at our rail pressure. Much more horsepower.
Old 05-19-2007, 12:27 PM
JASON11WS6's Avatar
Okay, so it looks like 60# injectors should hold up to an 700 rwhp motor which is where I want to be for now. But the new question is can they hold that kind of power level with E85?
Old 05-19-2007, 03:36 PM
camarols1's Avatar
Use BSFC = .80 for NA, .90 for forced induction when using E-85
This will be a good starting point as you will need much more fuel for an E-85 tune.
My former carb setup wanted 30% more fuel at light throttle, and 45% more at WOT!
