Injector Size for X3/Stock Heads
Old 08-22-2007, 11:13 AM
MemphisZ28's Avatar
Default Injector Size for X3/Stock Heads
Hey, Im building a stock displacement ls1 with 241 heads. ls6 intake, vengeance x3 cam (226/228 .58X lift) with long tubes and offroad pipe. The calculator shows me needing only a 29lb injector for 450crank power. not even sure if my combo will make that much. Would I be ok with a set of 28lb CTS-V injectors? Found a good deal and the 36lb SVO ones seem like pure overkill for my application. What do you guys think?
Old 08-22-2007, 12:03 PM
Nasty N8's Avatar
You should be fine with stock 28#ers you will need to upgrade the fuel pump as well.
Nate
Old 08-22-2007, 03:58 PM
MemphisZ28's Avatar
#28s with an upgraded fuel pump? My buddy ran 36lbs with stock fuel pump and a 125 shot into the 10's
Old 08-22-2007, 03:59 PM
MemphisZ28's Avatar
not trying to correct you just wondering Anyone else have exp with this? I shouldnt break 400rwhp and im thinkin the 28.8 CTS-V style should get it done. Any other experiences or opinions?
Old 08-22-2007, 04:18 PM
2QUIK4U's Avatar
The 28# injectors will be fine. My stock ones were good to 450rwhp. No need to replace the fuel pump either.
Old 08-22-2007, 04:29 PM
Frost's Avatar
They were, but you are the exception Bri
I usually see the 28lbers poop out about 405-420rwhp on an M6, 395-410 on a locked A4 .... but it's a crap shoot there too because the pump usually runs out of steam around the same time as the injectors.
Old 08-22-2007, 09:04 PM
MemphisZ28's Avatar
well, im not sure what to do at this point because half of the people say yes half say no, this car is never going over 6200 RPM and is not a race car. conufsed
Old 08-28-2007, 08:21 AM
MemphisZ28's Avatar
got 38lb injectors for agood deal now gotta figure out wtf to tune it with!!
Old 08-28-2007, 08:50 AM
ZL1Killa's Avatar
yeh glad you got some bigger ones, 28.8#ers would have been maxing out for you...theres no since in upgrading the fuel pump on the stock injectors... just go ahead and do both or just do new injectors...those 28.8s don't last long
Old 08-28-2007, 04:01 PM
MemphisZ28's Avatar
I agree. my buds vette with same cam and stock heads was maxxed with 28s. Gotta figure out how to tune this beast though building an ls1 is like a snowball rolling downhill.
