3:73 or 4:10 gear 6 speed street only
Old 11-11-2008, 06:57 AM
jester ls1's Avatar
Default 3:73 or 4:10 gear 6 speed street only
Do you guys think I should have the 3:73 or 4:10 gear installed this will be driven on the street only and it does have the hurst 6 speed.
Thanks for your help!!
Old 11-11-2008, 07:13 AM
VTC_WS6's Avatar
4:10's make for a pretty damn tight gear for DD, I just had a S60 installed with a set of 4:10's but I don't DD this car so it's alright, I don't think it'd be too enjoyable for everyday but then I'm not in the position to say. I will say that it makes the car a helluva lot of fun though! Using 6th around town is a new experience too lol!
Old 11-11-2008, 07:16 AM
PewterMNZ's Avatar
I have 4.10's street only. They are a blast. 1st is kinda useless.
Old 11-11-2008, 08:04 AM
ndfrsd6's Avatar
i have 4.56's and drove for a while with them ( wrong section though )
Old 11-11-2008, 08:08 AM
Platinum WS6's Avatar
3.73's
Old 11-11-2008, 08:14 AM
janaka's Avatar
I have 3.90's in my datsun (ls1 and T56) and I think its great. Awesome launching and highway cruising is still good too.
Old 11-11-2008, 08:36 AM
dankl's Avatar
4.10's are fine for a DD. I've got them and never once regretted it. Unless you plan to go FI down the road, do it! Just be careful if your planning on putting them into your 10-bolt
Old 11-11-2008, 08:50 AM
PewterMNZ's Avatar
I have them in my 10 bolt. no problem yet
Old 11-11-2008, 08:51 AM
Evans752's Avatar
I use to run 3.73 in my factory 10 bolt and I changed them out for 4.10 (before I ordered my Moser 12 bolt) and the car gained a tenth and a half from 11.91 to 11.77 on Mickey Thompson Drag Radials (a week apart in time, same track and the only change made.) On the street the 4.10 are funner to drive, gives you more low end power (grunt), gets you into the RPM range the LS motors like (perform) but on the street if your going to hook at all with any modification done you will need a set of drag radials. With a 6 speed I didnt see any real gas milage change but I don't drive my car everyday anymore.
Old 11-11-2008, 11:14 AM
SSdreamz's Avatar
if you have a M6 im assuming you have 3.42s now. it would seem pointless to me to go from 3.42s to 3.73s if you are only on the street. just my .02 but i am bias with my 4.10s
Old 11-11-2008, 11:27 AM
Adam1982's Avatar
I have an M6 with a dana 60 & 4.10s as a DD, I love it and have no problems with it.
Old 11-11-2008, 11:29 AM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
This is a very easy question to answer IMHO. My car has had 4.10's in the rear for about seven years. Car has been used as a daily driver when the other car was down. Have driven about 80,000 miles with 4.10's.
o Fun to drive and enjoyment you can't beat the 4.10's. They tend to make more noise etc.
o I like being able to drive around in 6th gear at 45-50 mph in the city.
o Street racing the 4.10's aren't so hot. It's very easy to spin and you may have to shift to 5th when with 3.73's you wouldn't.
o If you want to have fun and make the car easier to drive than stock go with the 4.10's. If you want to street race the 3.73's are the better choice. I'm happy with the 4.10's and still pick them over the 3.73's for a daily driver.
Old 11-11-2008, 12:44 PM
jester ls1's Avatar
Thanks for the advice! I have 4:10's in my 2007 chevy truck with 20" wheels. The gear change was huge, now my truck spins the tires easy! But it is automatic. Still struggling with this but I think I will select the 4:10's for the fun factor.
Old 11-11-2008, 12:46 PM
dankl's Avatar
Do it and don't look back. They should come stock with a ratio closer to the 4.10 then the 3.42...
Old 11-11-2008, 12:51 PM
$O$OE's Avatar
i heard with 3:90's u get the drive ability of 3:73's but lunch as good as 4:10's
SS4Luck's Avatar
4.10s are the greatest mod you will ever do to your car
Old 11-11-2008, 01:39 PM
noah89's Avatar
Absolutely the best mod I've done. Broke the 10 bolt and went with the Strange 12 bolt loaded with 4.11's. The only problem is hooking on the street. DR's going on the in the spring. The fun factor just can't be beat wth the M6.
Old 11-11-2008, 02:08 PM
Adam1982's Avatar
My 4.10s have just the faintest whine at about 50-60 mph in 5th, nodoby but me can hear it either
Old 11-11-2008, 02:14 PM
dankl's Avatar
Mine are just as quiet as the stock were. Granted it's in a 12bolt, but if set-up properly, noise should not be a problem to worry about.
Old 11-11-2008, 02:27 PM
StoreKeeper's Avatar
Thumbs up
I have 4.10s and it's the best change I made
Rx Bruce/StoreKeeper99Z28
Quick Reply: 3:73 or 4:10 gear 6 speed street only
