Breaking in new gears
Old 02-12-2009, 09:56 PM
sasquatch's Avatar
Default Breaking in new gears
Just went fron 2.73's to 3.42's. What is proper break in for these gears? Tried the search but its down.
Old 02-12-2009, 10:03 PM
DiabloFormula's Avatar
It should be 2-3 heat cycles.....i.e. run at normal speeds for about 10 miles then cool down for 30 or so minutes.
Old 02-13-2009, 08:13 AM
SS1875's Avatar
Here is what I was told by person who built my rearend.
standard, plain, regular 'ol parts store 80/90 gear lube... definetly no synthetics though.
do 3 heat cycles with regular street cruising driving... no sustained highway speed or launches. after minimum 3 heat cycles, then do whatever you like. heat cycle is from cool to full operating temp, then back to cool. usually 1-2 hours cool time.
after minimum 500 miles change out the gear oil. use whatever you like and what viscosity fits your needs.
This may differ for you slightly as I am running a Tru trac in my Fab9"
Old 02-13-2009, 08:19 AM
alamantia's Avatar
take it to the track
Old 02-13-2009, 08:25 AM
TransAmdriv3r's Avatar
Im going to be doing this too, probably next week. Should i leave out the posi additive till after the heat cycles when i do the gear oil change?
Old 02-13-2009, 11:19 AM
alamantia's Avatar
the gear manufacturer laps the teeth before they ship them to you. The majority of the heat generated is from the bearings breaking in, not the gears. A good quality lube will not break down under high heat to the point that it will damage the teeth. Just drive it.
Old 02-13-2009, 02:57 PM
Ihasfip's Avatar
Jason at TDP told me when he did my gears to do about 15 heat cycles. Drive for about 15 minutes and then let it sit about 2 hours. You should have about 500 miles before you beat on them.
D
Old 02-13-2009, 04:57 PM
Camaro Ryder KV's Avatar
floor it every chance you get, brake torque @ 5k rpm at every red light and go on the highway and stay in first gear!
lmao, just joking
i have also heard 15 cycles as a few posts above me said
Old 02-13-2009, 05:09 PM
sasquatch's Avatar
Thanks guys for the input. I was told by the guy who did the setup to just drive it but don't beat on it . Just making sure.
Old 02-13-2009, 07:14 PM
jetlag's Avatar
Don't be disappointed if it still whines after you do that fancy break-in.
