ABS Inop and brake light on after rear swap?
Old 02-13-2009, 06:06 PM
RARON455's Avatar
Default ABS Inop and brake light on after rear swap?
got a question for you guys who swapped rear ends, I put a QP ford 9 in my car and did not keep the abs system, I just unplugged the connector, and went on about my business. I will be getting an ABS delete system but what did you guys do about the lights on the instrument cluster, the ABS inop and Brake light stay on. I have a 98 T/A is this something that a tuner can tune out or what, Oh yeah dont recommend pulling the bulb, because anyone who has opened one of these up (myself included) knows that there are no bulbs in it, just soldered LED circuits.
I know I am not the only one who has this problem right?
Old 02-13-2009, 06:19 PM
SS1875's Avatar
I took the cluster out and put black electrical tape over them. On a 98 I believe you can do something with a jump wire on the PCM pins to trick it.
Old 02-13-2009, 07:28 PM
SS1875's Avatar
Finally found it, here you go.
Ok, for anyone wondering. On a 98..
pin 7 to pin 12 turns the ABS INOP light off.
pin 16 to pin 12 turns the BRAKE light off.
Info came from steve @ SJM. I have not tried it yet, but thanks Steve!
Old 02-14-2009, 01:18 PM
RARON455's Avatar
thanks bro I'll give it a shot and see how it goes, Hope I dont let the magic smoke out of the PCM.
Old 02-22-2009, 04:30 PM
dudeman's Avatar
what about 99-02?
Old 02-22-2009, 11:24 PM
ShevrolayZ28's Avatar
Originally Posted by dudeman
what about 99-02?
Negative. That only works on 98s. On mine I opened the gauge and blocked the light with black tape.
Old 02-23-2009, 07:38 AM
dudeman's Avatar
Wink
good to know!
Old 02-23-2009, 07:41 AM
spaz1's Avatar
Excelent info. I will have to keep this trick in mind for when I do my swap.
Quick Reply: ABS Inop and brake light on after rear swap?
