Help Identify My Rear, lol
Closed ex-Sponsor Account
I know this forum is more car based but rears are rears right.
I bought a 2003 Silverado and decided to buy a Detroit TruTrac for it because I was having serious traction problems at the track. I did 18 sec in the 1/4 spinning the whole way, lol. DR's helped a lot(13.9 1/4) but still some wheel spin so I can't hammer it.
Any ways, I went online and ordered a DTT for the Chevy 8.5/8.6 10 bolt assuming that is what I had since they come standard on the Silverado. Problem is my truck is a foreign(Mexico) model so it has a different rear end(Latin rear ohh great now I am thinking Vida Guerra). The shop that was going to install the DTT told me that I did not have a 10 bolt but a Dana. They were not sure exactly which one only that it was smaller than the 60.
I looked online and it looks like a Dana 44. I went to another shop and they said it looked like a Dana Super 44 and in order to get a Posi in there I would need a c-clip eliminator and a bunch of other stuff. It would cost about $1600-1800.
Can anyone here tell me what rear end I have? And if I can get some sort of Posi in it?
Here are some pics I took.
A much cheaper way would be to go the junkyard and find you a Z71 rear end. They have posi in them already. You could probably pick one up for a couple hundred and swap them out. The Dana should go for good money to the 4wd enthusiasts and put that money towards more go stuff. Just my .02
You might also check on the performance trucks sight up top and see what they say also.
Yes, it could very well be the Super 44. If you pull the differential cover and get me the numbers stamped on the ring gear I can tell you waht options you have. You do not necessarily have to do a c clip eliminator. Let me know.
Jeff
Jeff
BTW, I found this one "Semi floater 14 bolt 6 lug chevy differential from a 1991 chevy truck". Would it work? Supposedly the Avalanch and Esky also have a 14 bolt but the suspension is totally different.
I am headed to a local shop(only a two hour drive) so they van check out the diff as they think they might have something. Don't want to get my hopes up to high but I will be crossing my fingers.
Well I drove to the shop and they had a posi made by Dana/Spicer for my Dana Super 44. But when they removed the inside(I think they call it a carrier) it had holes for bigger axles than a standard Super 44. So I am back to square one. I took some pics of the internal parts but don't know how to post the pics online as they are on my phone.
Any word yet on the numbers stamped on the ring gear.
