Help with noise
Old 03-04-2009, 09:25 PM
brapril714's Avatar
Default Help with noise
The noise sounds like it's coming from both sides, depending on if you are in the driver or passenger seat. I occurs on turns and straight when slowing down. Pressing the throttle seams to have little affect on it. Never hear the noise above 30mph or on highway. Hear it on rough roads more than smooth when going straight, always on corners. I had the rear rebuilt in may of 07.
I really cannot describe the sound very well. Not high pitched, kind of a rumble and clunk some times, maybe loose marbles.
Could this be u-joints?
Thanks in advance.
Old 03-05-2009, 05:23 AM
EPP
EPP's Avatar
It could be the u joints if you hear a clunking type of noise. It could also be your torque arm, if it is the oem one. Check this link out. http://www.exoticperformanceplus.com...php?service=58 Bob
Old 03-05-2009, 10:49 AM
Jawsgear's Avatar
Nope it is gonna be bearing noise. Possibly a bad axle shaft as well.
Jeff
Old 03-05-2009, 07:39 PM
brapril714's Avatar
Should I pull the axles and check the wheel bearings?
Old 03-06-2009, 04:23 AM
EPP
EPP's Avatar
It certainly wouldn't hurt, but I'd check out the simple to check off the list things first. Bob
Old 03-06-2009, 05:52 PM
brapril714's Avatar
Jacked rear up, car in park and spun tires by hand. tires spun opposite of each other, I assume normal.
Layed under rear and spun tire by hand and listed directly above me, I could hear a slight noise in the pumpkin. to my untrained ear it sounded like the differential letting one tire spin on way and the other spin the other.
Put car in drive and could hear no noise while it was in the air.
Checked fluid and it started to come out as soon as I unbolted the fill hole.
I grabbed the u-joints and they would spin, maybe 1/8" each way, the same as the yoke on the rear end. No play up and down. Pushed and pulled on tires and they moved very little if at all.
Drove around on the nicest and smoothest road I could find and could hear the noise below 30mph, It's not constant and comes and goes.
Old 03-07-2009, 11:35 AM
brapril714's Avatar
I was wrong on one part. The noise goes away when throttle is applied. What could this mean?
Old 03-10-2009, 04:24 PM
brapril714's Avatar
any body?
Old 03-11-2009, 03:52 PM
brapril714's Avatar
nothing, huh
Old 03-13-2009, 11:56 PM
brapril714's Avatar
noise has gotten 10x worse in the last 2 days. It sounds like something is loose
Old 03-14-2009, 01:36 AM
cody161's Avatar
possibly bearings like someone said earlier. the shavings could be getting worse and making the sound louder. but at the same time it seems like it would do it all the time if it was bearings.
Old 03-20-2009, 09:05 AM
brapril714's Avatar
Pulled cover this weekend and no shavings. I noticed on the housing where you bolt the cover to, there is a hole on each side, I assume to let fluid go to the outer axle bearings? The passenger side was full of rtv silicone and the driverside was almost full.
I replaced fluid and drove around, this is a dd so I couldn't tear into any more. Noise is still there just not as bad. Notice driving that on wide sweeping turns, letting the car coast, the noise is almost gone on left turns but alot worse on right turns. Could this be axle bearings, I laid under the car and heard nothing. When I spin the rear tires by hand I hear a woop-woop. Nothing from the differential at all. U-joint next to transmission is make a chirp every 1/2 turn or so.
Got a quote to rebuild the rear, and I'll probably wait and buy 9" or strange 60, but that is a way's in the future. I only have 4 months and the car is paid off, hope it will last.
Sorry for the rant.
Old 03-20-2009, 09:08 AM
CodeRed2000SS's Avatar
Jeff
yep, sounds like bearings to me
Old 03-20-2009, 05:33 PM
brapril714's Avatar
Took the car to 2 different shops today, and both said the noise was not coming from the rear. They both suggested front u-joint. I'll replace and let you know.
Old 05-04-2009, 03:19 PM
brapril714's Avatar
Replace u-joints and still have noise. I give up, if it's the rear (leaning toward the torsen going out, since it will not make the noise on a lift) I'll drive it till I can afford a 9" or S60.
