broke my 9", need new case
Old 04-27-2009, 01:47 PM
cjg454ss's Avatar
Default broke my 9", need new case
I broke my 9inch at the track last week. i need a new thirdmember. pinion bearing housing cracked. i was running a c74w case. is the one below much stronger. what do you guys recommend.
thanks
http://store.summitracing.com/partde...700+4294841488
Old 04-27-2009, 02:01 PM
wrd1972's Avatar
Post some pics if you can.
Old 04-27-2009, 02:16 PM
Mikey 97Z M6's Avatar
Either one of the Strange center cases will be stronger than any of the factory production ford cases (except the ford motorsport case). The Strange budget 'S' case is rated to 800 horsepower, and their other case is rated much higher than that.
Mike
Old 04-27-2009, 02:21 PM
If I were you I'd also step up the the 3.25" bearing case so you could upgrade to 35 spline axles at some point down the road. It doesn't cost any more except the larger bearings are little more expensive.
Mike
Old 04-27-2009, 08:19 PM
cjg454ss's Avatar
Mike
i have 33s now, i mtrying to learn about the FORD part in my car, with the bigger bearings what else needs to be changed? will my spool still work? also what yokes are you running?
also what gears to i get? i know some are stronger?/
Old 04-28-2009, 07:50 AM
cjg454ss's Avatar
anyone else? cases you use? gears? ect
Old 04-29-2009, 04:35 AM
scidav87's Avatar
If you switch from a 33 spline to a 35 spline, you'll need a 35 spline spool! Also, with a 35 spline setup you will need a 3.25" carrier case, and of course new axles... Stick to 33 spline, you'll be fine. I have the stange aluminum 3.25" case, 4.00 ratio gears and a spool (35 spline) with the summit racing aluminum pinion support. I used flea-bay and summit racing personally...
Old 04-29-2009, 02:24 PM
You can step up to the 3.25" bearing case and still use your current axles/spool. You will just need the larger 3.25" outside diameter bearings for the spool, which, if you broke gears you'll probably want to replace your current bearings anyway.
FWIW, If I were in your shoes, there's really no reason not to step up the bearing size.
Mike
Old 04-29-2009, 03:15 PM
cjg454ss's Avatar
Mike
are the bigger ones really stronger? its a turbo setup so i dont think it will be shocking the rear that hard. the stock cast case just seemed to weak in general.
Old 04-29-2009, 06:31 PM
Any time you can go with a larger bearing to distribute the load better is a good thing IMO. The real question is, why wouldn't you?
Mike
Old 04-30-2009, 06:41 AM
cjg454ss's Avatar
Mike
yeah good point, the summit tech said larger ones run cooler, and cause i only run at the track really he said it didnt matter.
