Which Rear for Auto-X/Handling
Old 06-07-2009, 10:15 PM
SoxXpupPeT's Avatar
Default Which Rear for Auto-X/Handling
The question is which rear should i get that isnt going to upset the handling to much ? my car is daily driven and driven hard the majority of the time. it will see some autocross and some track time after i do the swap.
Old 06-08-2009, 04:48 AM
BIG BAD BLACKSS's Avatar
I say fabbed 9inch since with the aluminum center it can weigh less than a factory 10 bolt. Less unsprung weight is always nice. Only oyher rear I would consider is maybe a 12 bolt. S60 is definitly out as its a fat pig weight wise.
I'd personally be looking at the midwest chassis fabbed 9" with a true trac.
Old 06-08-2009, 12:41 PM
xXxSilveradoxXx's Avatar
If weight is your concern check this out, LS1Tech Axle Weight Thread.
Last edited by xXxSilveradoxXx; 06-18-2009 at 12:26 PM. Reason: because it's a high priority for NHRAMAN!
Old 06-08-2009, 05:30 PM
SoxXpupPeT's Avatar
i would Love to get a midwest 9" but idk if ill have the cash flow for such an incredible rear. i was thinking of the quick performance 9" or something equivalent.
Old 06-08-2009, 07:54 PM
LS1Tech Premium Sponsor
ssvert99's Avatar
start adding up all the components to make the QP setup even close to the strength, weight, and value of the Midwest Chassis setup and you will find that the overall cost is not much different. the most costly part of the entire process is the center section, no matter whos rearend. I also include small things the others don't that make these great for autox/roadcourse cars as well. Watts link setup is available now even.
Old 06-09-2009, 04:10 PM
Viper's Avatar
Heck after all these years autox/road race you can't beat the 10 bolt with a T2R Torsen differential. I've been doing this 10 years and haven't broke anything and I'm putting down 450HP. With autox/road race you don't launch the car so it's no big deal to the 10-bolt. The differential makes the difference; I also have a TA cover for the rear.
Old 06-10-2009, 06:29 AM
toadzq8's Avatar
+ 2 on what Viper said, Can't beat a 10 bolt with a T2R, maybe put a pair of light weight rods in it and weld your tubes, for a track day or Auto-Xing hard to beat. Sure a fabed 9" might be lighter but it still soaks up HP, and cost big $ to get it that light, drilled rods, alum center etc,
Old 06-18-2009, 12:13 AM
99Z2ate's Avatar
Where do you get a T2r for a 10 bolt these days??
Old 06-18-2009, 06:13 AM
toadzq8's Avatar
Try: On Track Performance Solutions
Old 06-18-2009, 06:34 AM
Viper's Avatar
www.stranoparts.com
Sam is happy with these too:
http://www.stranoparts.com/partdetai...ID=0&ModelID=7
Old 06-18-2009, 12:06 PM
99Z2ate's Avatar
Just got an email back from Strano, guess I wont be buying one of these for my DD...
"I have chosen to stop selling them after a rash of durability issues. I personally fried two within a year. We have a number of other options, but I no longer carry the T2R."
Old 06-18-2009, 12:08 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
Originally Posted by xXxSilveradoxXx
If weight is your concern check this out, LS1Tech Axel Weight Thread.
please...it is spelled = AXLE.
Old 06-18-2009, 12:25 PM
Took 10 days to be noticed, correct spelling must be a high priority on here.
At least I can spell CAMARO! (I'm not saying you can't, just saying I've seen worse!)
