I need to find stronger axle's that will work with an abs/tcs car
The part dorman makes will not work for an abs/tcs car, I dont wanna spend a fortune I just want something stronger that's all. I've been driving it like this for months not realizing that it's screwed up. HELP
Has anyone had issues with the calipers now being off center and rubbing. Put the moser axles in and the caliper mounting bolts are rubbing against the back of the rotor and the calipers rub when going around corners. Cut the bolts and spaced out the calipers its better but dont want to do anymore...
Any have the same issue and find a solution?
