Has anyone ever ran a 8.5 10 bolt in a 4th gen?
Old 11-24-2009, 05:55 AM
98Z2885's Avatar
Default Has anyone ever ran a 8.5 10 bolt in a 4th gen?
Just curious, we just picked one up for my 67, I know they are a lot tougher.
Old 11-24-2009, 06:21 AM
cambirdracing's Avatar
Not sure you can get it to work without a lot of fabing. My wife and I run in the mid 10's with her 2nd gen Camaro and my 1st gen Firebird and have the 8.5 10 bolts.
Old 11-24-2009, 06:31 AM
Internet Mechanic
BlackScreaminMachine's Avatar
The biggest thing like said is having similar mounting points, especially when it comes to a TQ arm. It has been a while for me so I forget if the 8.5's have the Dog Bones on top....
**Edit**
I found this and I see the mounting points on top, so again, I see some fab work ahead of you.
Old 11-24-2009, 10:25 AM
That one ^ looks to be out of an A,B or G body. Def not a F body.
Old 11-24-2009, 11:24 AM
tillery's Avatar
Your right-a 1st and 2nd gen had leaf springs. But carefull tho-some 1st gens came with a weak 7.5- 8.2 rear. the axle width is wider on the 2nd too isnt it?
Old 11-24-2009, 01:22 PM
98Z2885's Avatar
There plenty tough. They had to be though coming from the muscle car era.
I have only heard of the 8.2 in the first gens. Ive never seen a 7.5 in a first gen. Even the 68 6 cylinder we had, it came with a 8.2
Old 11-24-2009, 01:42 PM
I am pretty sure the 1st gen only had a 8.2. I actually got my 8.5 out of a 73 Olds Cutlass just b/c it had press on axle bearings. I cut it up and welded on leaf spring pads. Then I cut 5" out of each axle when I narrowed it and the frame. Still has the factory style press on bearings, no leaky c-clip eliminators. Of Course, I know how to get them not to leak.
Old 11-24-2009, 01:53 PM
tillery's Avatar
Your right-I had a 8.2 under an Omega. I had to think about it. Set it up like the GNx was. Still alot of fabrication.
Old 11-24-2009, 03:48 PM
98Z2885's Avatar
I just wonder how good one of those would hold up to lets say mid 400 hp, and automatic. We got this one complete for 75.00 and it was the right width. If you could pick it up for 75.00 and then just have all the fabrication done, it would still have to be a heck of a lot cheaper then, 12 bolt or 9"
Old 11-25-2009, 06:22 AM
Fabrication would probably make up the difference between a 12 bolt ready to bolt in and the cost of the fab job.
Old 11-25-2009, 07:05 AM
Internet Mechanic
If people are looking to do fab work, build a Ford 8.8
Old 11-25-2009, 11:10 AM
**Edit**
This one looks like a 8.2. I thought 8.5 cover was more round.
Quick Reply: Has anyone ever ran a 8.5 10 bolt in a 4th gen?
