Going to 4.10s
^^^ the 3-series is what youll need.
depending on miles might look into a full bearing kit while youre at it.
thunder racing sells a kit complete with eveything for 400, and then jaws gear will price match that plus free shipping from what i recall.
Ok so I can just order a standard set of gears and be fine then right? whats the steepest gear I can run with the 3 series carrier? Also the car only has 20 k miles so bearings should be fine.
Just order up the 3 series 4.10 and you're good. Highest I have seen is a 4.56 I believe, but who knows what all is out there. 3 series 4.10s are a direct bolt in.
