how do you think my 7.5 will hold up
Old 03-18-2010, 02:01 AM
suicidal racing's Avatar
Default how do you think my 7.5 will hold up
welding axle tubes,4.10 gears that i might get mykronited(sp),ratech solid pinion spacer,girdle and running 2 pass axles..i just need this thing to live on a 300rwhp,4500 stall,fmvb th350 and 275 radials..before i get the why waste the money..ill have 300$ into the rear and it needs to be gone threw anyways seeing it has 150k on it...plus my 9" im going to do will go into her when i put the glide and turbo lsx deal..my 9 will be for the track and track only..right now i still street drive her an will for 6 more moths probley..
Old 03-18-2010, 06:47 AM
EPP
EPP's Avatar
With the automatic you might be okay on the street. Bob
Old 03-18-2010, 06:55 AM
yeah she will see some track use..car race weight will be 2900#s or so...im looking for 1.30s for 60ft..
Old 03-18-2010, 07:02 AM
the_merv's Avatar
Ya I don't see that happenin with a 10-bolt.
There is nothing wrong with driving a 9" on the street..I do it all the time, as well as many others.
Old 03-18-2010, 08:37 AM
my 9" im going to do will be for the track..like i said..pro gears,40 spline axle gun drilled an so on..its going to be a full tilt race rear rear..im def not going to put street wear an tear on it...i know guys are going low 11s and 10s with 10bolts an making much more power with juice an at more weight....
Old 03-18-2010, 09:27 AM
the_merv's Avatar
I killed my 10-bolt at 3450 Track Weight, and that was with a 3600 Stall and 3.73's, I got about 12 mid 1.5 60ft's out of it.
Old 03-18-2010, 09:40 AM
01ssreda4's Avatar
The ten bolts are hit and miss, but live a hell of a lot longer behind an auto thats for sure
Old 03-18-2010, 02:12 PM
yeah..i see there hit or miss..thanks for the info merv..i think me being less then 3k for weight will help me..its def easier on parts vs 3400 an 3600#s like some cars..
im pretty much eliminating all the weak points i think..but the posi..i wish some one made a spool..but welding the tubes will solve the housing twisting which is a killer,solid pinion will solve the crush sleeve from going out of wake an killing my gears,pass axle is an old trick i forgot about till some one reminded me about it the other day..there running 6.20s in the 1/8th in there 3rd gen with juice, an the mykronite process makes the gears harder so they dont break as easy..the spool is the only thing im missing..
Old 03-18-2010, 02:53 PM
duh
duh's Avatar
the problem with the 7.5 is in the ring gear size. Since it's only 7.5" in diameter, you're transferring a bunch of power through a small little area. That's why the 9", 12 bolt, and S60 all live.....all three are, or almost are 9" diameter ring gears. You could successfully run an 8.8 under high hp conditions as well if you build it correctly. It all depends on how much you beat on your little 7.5 as to how long it'll last. With your power, you should be fine.
Old 03-18-2010, 04:09 PM
yeah..i know the ring gear is the weak point..if a company would step up an build a race ring gear it would help alot..thats why im going with the mykronite deal..it shot peans the ring and polishs it...an yep a 8.8 can take 2400 plus hp when done correctly..bd who runs radials an been 6s uses a 8.8 rear..
