Whoo! Bent axle!!! F-ing dumb drivers!
I had a car whip out of a parking spot along the side of a road and run me into a median, THEN DRIVE OFF after I do a complete 180 after smashing my rear driver tire on the curb.
My Torque Thrust 17x10 is cashed. They don't make that size anymore, so two new rims (17x11) and tires are ordered. There's $900!
I just know the axle HAS to be bent. The wheel wobbles like no other. Is it ok to replace an axle in this type of situation, or just get a whole other rear end? I don't want a 12 bolt just yet(funny thing is I always said I'd use a broken 10 bolt as my excuse to get one, but not in these circumstances).
How do you replace an axle shaft? Is it difficult? Does anybody know where I can get one for cheap? It's a four channel (ABS and traction) rear end, so I take it I would need a specific axle?
Any help would be appreciated guys, thanks!
You should be able to just replace the axle, if the tube isn't bent. You should be able to check the axle without a wheel on there. Just spin it around by hand and watch to see if it wobbles.
To change the axle.
1.) remove wheel, caliper and bracket and rotor
2.) remove diff cover (remove bottom bolts first and leave one bolt on the top loose, pry the bottom off with a screwdriver with a drain pan underneath, then remove the top bolt.)
3.) There should be a pin that runs through the center of the carrier with a small bolt that runs through it. Remove the small bolt and the large pin that runs through the carrier.
4.) Push in on the axle flange and remove the c-clip. Pull the axle out of the rear end.
Reverse the procedure to re-install.
To change the axle.
thanks for the help guys. i'll get my wheels in next week and when I take the current ones off I'll scope it out and give it a few spins. like I said, I'm pretty positive it's going to be bent too
Is there a good possibility the rotor got bent too? On my way home I noticed a pulsating feeling when i pushed in the brake, and I could here a brand new scraping/squealing with the rotation of the rotor. Could a bent axle or rim cause this, or should I plan on a new rotor too?
Brake rotors usually don't bend, they brake. Because of all the heat cycles. My guess is like you assume, axle or houseing is bent, and causeing brakes to pulse. More than likely just the axle since if the houseing was bent, then the brakes would move with it and not pulse. Good luck, and thanks for the tip on just silicone. I thought thats what most did.
Silicone works, but there is this stuff called "Right Stuff" that is the cats ***!!!!! Kinda expensive, like $30 for a "cheeze-whiz" sized can, but it is hands down the best stuff Ive used. Any parts store should carry it, I know Ive picked it up at Oreilly, Napa, and CarQuest........
