You guys who have replaced your rear pinion seal
Old 07-13-2010, 01:07 PM
98RedBird's Avatar
Default You guys who have replaced your rear pinion seal
Did you go with a GM replacement or from an auto parts store like Napa, O'Reilly, Autozone, Advanced??
Old 07-13-2010, 02:19 PM
dutinsss's Avatar
Originally Posted by Jays_SSZ28
2002 uses a two piece seal, the piece that goes into the housing has a larger ID and it had a piece that slides over the yoke.
All 7.5 seals are the same from when they were first put out until 2002.
If you use an older seal you need to take the part off the pinion.
Last time I checked the parts stores didn't have the 2002 and up seal. they will give you the old one, when you install that with the yoke seal on the yoke it'll rip the rubber out and it'll leak.
Point is, for a 2002 and up go to the dealer or take the piece off the yoke and use the older seal, 2001 and down, any parts store should have the older style.
what he said. i replaced the seal in my '02 with one from the parts stores and it leaked and had to do it all over again. it LOOKED like it'd work.
Old 07-13-2010, 06:05 PM
NC01TA's Avatar
I had a slight leak in mine and had it replaced at the dealership in Jan of this year when it was time to change the differential fluid. They charged very little extra. It was done with the right GM part and done well.
Old 07-13-2010, 06:10 PM
Nemesis350's Avatar
I've replaced mine with one from Advance autoparts. I haven't had any problems with it
Old 07-13-2010, 07:13 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Used a parts store piece as well with no problems
Old 07-13-2010, 07:25 PM
98RedBird's Avatar
So you removed the 2 Piece seal that the guy was talking about earlier in the tread?
I've swapped it on a '98 before and it was cake work.... Apparently the '02's are different?
Old 07-14-2010, 11:54 AM
jlasserton's Avatar
I'd go with the GM replacement unless you have a auto store you absolutely trust. I think it just depends on how much you want to spend. Every store varies. I have usually opt out of auto stores such as O'Reilly and Napa, but that is just my personal opinion.
Old 07-14-2010, 12:20 PM
01ssreda4's Avatar
Go GM for sure. Dont take chances. They changed the design in 01. 98,99,00 got the first design, and 01 and 02 got the second design seal.
Old 07-14-2010, 12:59 PM
sscamaroburn02's Avatar
I would go to dealership and get GM replacement. I had mine done there twice and finally leak is gone. just waiting until I can get a 9".
Old 07-14-2010, 01:15 PM
Z28/2002's Avatar
It's been so long ago I can't remember, it was on my 02 CETA.
The seal I got was orange and it hasn't leaked.
Old 07-14-2010, 02:08 PM
The House is Rockin'
BLUES MAN's Avatar
i got my national seal from advance.
Old 07-14-2010, 03:43 PM
Moderator
jimmyblue's Avatar
I just took what they gave me in the Ratech master
kit. Those guys ought to know, I guess.
Question you should ask before getting all excited is,
"why is my pinion seal leaking?". Because simple wear
at 15Kmiles shouldn't be it. But crush collar being
pounded slack over time / abuse, or driveline imbalance
/ driveline angle issues, those will cause weepage and
will not be fixed by new rubber. Not for long, at best.
Might check the pinion play first and see if you're up
against something more.
Old 07-14-2010, 03:45 PM
01ssreda4's Avatar
Ratech sends the earlier style seal. If you have a late 01 or 02 you cannot use the seal that comes with a ratech kit. Or at least every Ratech kit I have ordered has been like this.
Old 07-14-2010, 03:47 PM
BLUES MAN's Avatar
well my ra-tech pinion seal that came in the kit leaked from day1, but maybe i was unlucky.
Old 07-14-2010, 04:31 PM
Jawsgear's Avatar
You can use the old design seal if you pull the rubber sleeve off the yoke, nut you need to make sure and polish that surface extremely well with some emory cloth or it will for sure leak again. If you look close you will see ridges and machine marks on the yoke when you pull the sleeve off. or simply go to GM and get teh right seal.
Jeff
Old 07-15-2010, 01:49 AM
davidz's Avatar
This would of been helpful before I put the old style seal in after doing my gears. Now im having to change it again. Might go with the GM seal for my 02 though.
Old 10-14-2016, 03:06 PM
-=Modified=-'s Avatar
Resurrecting an old thread. Anyone have the part numbers for the two piece pinion seal for a 2002 Camaro SS?
Old 10-14-2016, 04:43 PM
FirstYrLS1Z's Avatar
Per GM parts layout catalog
98-99 26026792
00 1st design 26026792
00 2nd design 12471523
01-02 12471523
Old 03-14-2017, 01:03 PM
RedTA02's Avatar
just called my local gm dealer, they gave me P# 12371523
Quick Reply: You guys who have replaced your rear pinion seal
