Whining noise...cannot figure out problem
I have a 94 z28 automatic. When I go over 25-30 mph it starts making a horrible whining noise. As I go faster it seems to get a little quieter but more high pitched. Seems loudest when I'm barely giving any throttle. I replaced all the bearings in the rear end and checked the gears, which had no wear ( stock gears). Now while driving it like this the abs inop light popped on. I don't know where to look anymore or have any idea what it could be. Any help? Oh and it started making the noise after flooring it one day on the highway
LS1Tech Sponsor
Make sure your factory torque arm, which is made out of stamped steel, is not bending. I have seen it happen and throw the pinion angle off. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
The Same thing happened to my dad after he had a new gear put in his Ford 9''. The crush sleeve wasn't compressed enough and when he put it under load it caused the pinion to move slightly causing wear and although it's set correctly now due to the wear in just the few miles he did, it still whines exactly how you've described. When you look at the gears though they look perfect. Hope this helps.
Did u replace the the bearing races? What preload/backlash did u set it at? And yes u might have to replace the ring gear. Even thou it looks good doesn't mean its good... how did the pattern look?
I noticed when I took off the driveshaft that when I turn the yoke it feels like there is a little play between when the teeth meet like it's not pushed in far enough or something.
