Drive line Vvvvvvibrrratttttion. Exhausting my options
Old 10-25-2010, 09:33 PM
STEEPSS's Avatar
Default Drive line Vvvvvvibrrratttttion. Exhausting my options
Here's the scoop:
Just put gears in my car (9"). Re-installed the center, and it vibes like a bish
I had the short style pinion yoke, with a stock length ds. I replaced it with a long pinion yoke, and upgraded driveshaft (who i bought from "danhr" a **** eating, bottom feeding member on here.
Its a denny's nitrous ready driveshaft. When I got it, the splines in the slip yoke were twisted. SOO i replaced it with a strange chrome moly yoke and new u joint. Put it in the car, it vibrated.
Had it balanced, Still vibrated.
Put in the stock DS, still vibrated
Checked / fixed my pinion angle.... Still vibrated
I'm running out of things to blame it on.
Vibration is increasingly worse from about 45. Feels like its coming apart at 60.
HELP ME FIGURE THIS OUT PLEASE
Old 10-26-2010, 12:49 AM
jimbo98z's Avatar
To me the nexti logical step is to remove the 3rd member and look at it. I'd check for axle damage too.
Do you have a spare set of wheels, i.e. drag radials or something you could try?
Old 10-26-2010, 07:17 AM
Restricted User
Supers's Avatar
You gotta use lots and lots and lots of detail....
Without being able to drive the car there is no way ANYONE will be even close to pointing in the right direction.
Let your local driveline shop look at the entire car
Old 10-26-2010, 08:43 AM
STEEPSS's Avatar
I appreciate the replies.
However, there was never any vibration before the gear / pinion yoke / slip yoke change.
So, that rules out tires, wheels, and axles.
Note: I can feel play at the slip yoke end, with the driveshaft in place. Even with the slip yoke fully pushed into the trans, I feel some play. Which leads me to believe the tailshaft bushing is worn.
IF that's the case, IDK why it would all of a sudden develop a vibration, when there is now MORE slip yoke in the trans than before!
Thoughts / opinions?
Old 10-26-2010, 02:18 PM
cambirdracing's Avatar
Does it vibrate when you put a side load on it? e.i. going around a bend in the road? Reason i ask is b/c I rebuilt the rear on my 94 v-d bird and put in another d/s and it still did it. Ended up being the front wheel bearings.
Old 10-26-2010, 03:25 PM
Lambert695's Avatar
God I hate driveline vibrations... are the yokes centered on the driveshaft and such? some u-joints dont like to center up. Also, sometimes from random vibrations that bushing in the tail housing of the trans can come off but then it usually shoots trans fluid everywhere. Did you bend anything when installing the new u-joints? Just trying to throw out ideas....
Old 10-26-2010, 07:14 PM
LPE 403's Avatar
Can't help asking did you go back to your original set-up in the short yoke, stock ds and start over? You'll have to 'root cause' the problem by starting at zero and sneak up on it...
Even dumber question...any chance a wheel weight fell off? Crazier things have happened.
Old 10-26-2010, 07:45 PM
STEEPSS's Avatar
We've had the car on a lift, and it still vibed, ruling out anything up front
U-joints are centered. The 1350 Pinion yoke has the little tabs on the end to ensure that. I was gentle in installing the u-joints, plus the stock DS also vibes
I can't, without setting up the gears again. When you take the pinion nut off, and replace it with a different one, the gear setup characteristics will be different. Not worth the chance, IMO.
I'm gonna take the wheels off and spin it again this evening, so to eliminate this chance. It is a possibility, but it would be VERY unlikely that it just so happed to fall off once I upgraded this stuff. I have heard of guys having bigger problems with the chromoly driveshafts transmitting vibration, as compared to aluminum, but the aluminum one still has it, so I doubt that's the whole issue
Thanks for the ideas. Keep em coming and I'll try them accordingly
Old 10-26-2010, 08:34 PM
30th6's Avatar
i hope you find out i have the same problem.mine vibates more when i turn left and almost quits when i turn right.mine has always vib with the moser 9in,3 diferent shaft, every pinion angle known to man.im thinking about getting adjustable lcas and try to tweek it from there.
Old 10-26-2010, 09:32 PM
libertyforall1776's Avatar
Have you checked your Trans mount integrity?
Old 10-26-2010, 09:53 PM
Restricted User
Supers's Avatar
Checking for vibrations on a lift and the driveline hanging is not going to help you...it will make it even harder...
You may very well have a problem at the rear, either a axle bearing or your carrier is about to fall out...
Old 10-27-2010, 12:22 PM
STEEPSS's Avatar
Good thought, I'll check it out.
First off, thanks for assuming my stupidity. I did it on a 4 post lift, with the suspension loaded.
IF it is a problem with an axle bearing, it JUST developed at the same time i put the gears in. Not saying it isn't, but it's at the bottom of the list.
Old 10-27-2010, 05:06 PM
30th6's Avatar
i just put new axel bearings in about 5k miles ago,and the carier is tight.any other suggestions?
sorry for the high jack been battleing this problem for about 4 years.........dam
Old 10-27-2010, 08:13 PM
Restricted User
Supers's Avatar
Not assuming you are stupid, it just happens that everyday when the term lift is used, it's not a drive on, no one uses the term 4 post lift unless you are bend-pak , in the repair world when someone says lift, it was not a drive on.. so i was going on when you said lift...
That is why i gave you that reply
The turning and changing the intensity of the vibe leads me to point at the axle...
It is also very hard to pin point vibes on line... it really needs tons of detail..
You're better off seeing a local shop that has and is good in that area of expertise...or you might end up with a bill for a new car.
.Check your lugs and wheel and make sure they're not loose and or the wheel has elongated holes
Old 10-27-2010, 09:07 PM
30th6's Avatar
ive had 4 different sets of wheels....nothing changed.i would love to take it to a shop but i dont no of one around my area thats worth a dam.guess its gonna vibrate.will the rear end being tracking sideways make a vib?i aligned it after the relocation brackets and it was off just a little.i cant remember the specs but i was in the red on the screen.thanks joe
Old 10-28-2010, 12:06 PM
STEEPSS's Avatar
Fair enough. I checked my tranny mount, and it was a little loose, so I tightened it up. Vibration is the same. ...........
Old 10-28-2010, 12:20 PM
But how is the tranny mount bushing that helps dampen vibration? Maybe it needs replacing? Or could you have a poly one already that is doing you no favors?
Old 10-28-2010, 01:16 PM
STEEPSS's Avatar
Its already a poly mount. I also have poly motor mounts. However, its not the problem, because it didnt vibrate at all before, and these were the same.
Old 10-28-2010, 01:59 PM
therobman's Avatar
sounds like the same problem im having drives fine under 40-45 but if im doing 50-60 and let off the gas it vibrates like a mother. but it only does it on the road ive tried preloading my suspension with it on a lift and it does not vibrate im working on it this weekend to see if i can fix the problem ill post up if i do
Old 10-28-2010, 09:18 PM
Restricted User
Supers's Avatar
If it is off you'll track sideways a bit...
Give some more detail
Quick Reply: Drive line Vvvvvvibrrratttttion. Exhausting my options
