4.10 Gears for my 99 Z28
I am looking into putting a set of 4.10s into my 10 bolt rear in my Camaro. As you can see in my sig, it is a 99 Z28, WITHOUT TCS. I was looking in Speed Inc to see what these will run me, and I saw that there were a few different companies that offer these gears.
http://www.speedinc.com/catagory.cfm.../%20Driveshaft
Allstar performance: $160
-Says these fit 27 spline axles?
Motive Gears: $190
Richmond: $200
Are any of these better than the other? Are some of these known for premature failures (more than the other - I know this only for a 10 bolt lol).
Thanks for the help!
Motive Gears: $190
Richmond: $200
1/8th mile I take it? I am looking to run at least a 7.9x with just bolt-ons with the 4.10s. Good to hear that your ten bolt is holding to some pretty good times. You do any of the 'upgrades' such as the spacer instead of the crush sleeve, differential girdle, etc?
No hell no not worth the money. I neglected to tell you that when I sprayed it two pass's later it broke the posi unit. Held fine on the motor into the 6's though. First time I sprayed it I had a bad burnout and it spun hard but it went 6.90 @ 109mph. Burnout is real crucial on my et street radials. Im building a 9" now.
ws6 store...gears, master/deluxe install kit, (you'll need it),differential fluid, 2 quarts gear oil ran me 337$
