Dana 60 options, no longer want spool. please help
First off let me say im running a strange S60. I would no longer like the spool im running in my S60. im reading into true trac and true lock units, 3 series or 5 series. I dont know what any of that means or what i need or should get. Its a street/strip car around 400 hp. any input will be greatly appreciated, thank you.
Is your car automatic or standard? If it's automatic, you can use about any LS unit. I would stay away from the Gleason Torsen unit as I have one and it's not worth a crap in my opinion. The clutch pack style are plentiful and are rebuildable something to consider if you need to fix it down the road. Just be sure of the spline count as some older units were 30 spline. Detroit Locker's are a bit rough on the street, you can read up on the good and bad. Many vendors here can help you, and the 4X4 guys have lots of info on their sites. Carl at CRP would be someone to talk with.
http://centralracingparts.com/index....te=common/home
Al 95 Z28 S60 w/spool
Thanks for the plug Al!
The series of carrier is in reference to what gear ratios will fit. The 3-series carrier for the S60 can accommodate the 3.54, 3.73, 4.10 and the 4.30 ring and pinion. The 5-series carrier can accommodate the 4.56, 4.88 and the 5.13 ring and pinion. You select the gear ratio desired and order the differential with the appropriate carrier.
The Detroit Locker is known for it poor street manners, it is noisy as in making knocks and clunks also sometimes feels like it makes Your car want to change lanes!
The Truetrac or the S-Trac would be My first recommendation for a street or a street/strip application.
You can message Me for additional information or call 7 days a week at any reasonable hour.
Carl
Carl
Carl
Carl
thanks
anthony
studderin, funny you posted on this because from what I was told you helped out with the bearings on my s60, I purchased it from a guy who lives in rochester. I forget his name tho, works at a lexus dealership. Iv meet you once through the wny fbody guys at the track one night.
