Converting a 3 channel to a 4 channel
Old 04-03-2012, 09:02 AM
Y2KSnakeEater's Avatar
Default Converting a 3 channel to a 4 channel
Hey guys, I have a 3 channel 10 bolt that Im needing to put in the Z. Currently its a 4 channel car. Ive seen post on how to convert a 4 to a 3 but Im having a hard time finding a thread for a 3 to a 4. Can someone help me out please?
Old 04-03-2012, 10:49 AM
Exeodus's Avatar
The 3 channel rear wont work because the reluctor ring needed for the ABS is mounted to the ring gear, where in a 4 channel rear it has a reluctor ring on each axle near the caliper mount.
Old 04-03-2012, 10:55 AM
Can I just convert the 4 channel to a 3 channel by deleting the traction control?
Old 04-03-2012, 11:39 AM
FirstYrLS1Z's Avatar
traction control cannot be deleted,it's part of the ABS system.
to convert a 3 channel rearend to 4 channel,the axles and backing plate assemblies from the 4 channel rearend have to be installed to the 3 channel rearend.
Old 04-03-2012, 02:25 PM
Which would be better....swapping the axles and backing plate or just swapping out the chunk?
Old 04-03-2012, 04:15 PM
what's the problem area,something wore out/broken ?,that's requireing the swap ? that info should have been put in your original post.
Old 04-03-2012, 06:40 PM
The gears I have now whine a little but the biggest reason I'm switching is because I'm going from a 3.23 to a 3.73.
Old 04-04-2012, 12:50 PM
Wicked 94TA's Avatar
Converting your 3 channel to a 4 channel is fairly simple, I had to do it with the rearend in my Z now. You'll need the 4 channel backing plates with the speed sensors in them, the 4 channel axles with the reluctor wheels and the 4 channel wiring harness that hooks to the 2 speed sensors.
Old 04-11-2012, 12:53 AM
cfiester's Avatar
Default 3 to 4
Agree with wicked 94 ta. just went through this on mine.
Quick Reply: Converting a 3 channel to a 4 channel
