10 bolt help
10 bolt help
I ran some buddy's on Saturday and I noticed like a humming noise on my rear end when I would let of the gas. So I stopped looked under the car see if I would see anything leaking or something cracked but nothing. After that I decide I better take the car home before I'm stranded so when I got home jacked up the car and took of the rear end cover to find my differential cracked. So my question is would it be easier if I just replaced it or get a whole new rear end
http://db.tt/jGYFbhFs
From my experience when swapping center sections the gear mesh pattern/backlash doesn't change enough to worry about. Meaning it can really be a super easy swap. However, you would need to check it before and after and know how to make adjustments if it was needed.
There another pic just a little further back and evyrthing looks fine besides what you see broken.
http://db.tt/6VgL2ZP0
Under the circumstances, everything would need to be pulled out for full inspection and cleaning of the housing. So yes a new crush sleeve would be needed.
