2011 4 piston brakes
I will be upgrading my brakes, wheels and tires all at the same time. I was wondering if anyone has put 2010+ Camaro SS brembo brakes on their 4th gen or if its even possible?
They are 14" 4 piston front and 14.25" 4 piston rear.
I've got a friend that will sell me his rotors, calipers, pads and lines all for about $600. which I don't think is a bad price.
I've read up a bit on the CTS-V and Z06 upgrades. I haven't seen anyone do this before.
The 2010+ Camaro SS Brembo calipers are the same as CTS-V calipers, except the mounting holes are larger and a different color. Use either one. If you use Z06 rotors you will have to space the caliper closer to the spokes by 1/4. If you use the Camaro SS rotor no spacers are needed, but you will to have the mounting hub I.D. turned to the larger size. I am using the Camaro SS rotors and the CTS-V calipers.
haha my bad, I though I clicked suspension and brakes not gears and axles
