First Attempt At Gear Installation. Reassurance Needed. Paddle Kit?
Hey guys, I finally ordered a set of Moser 3.73s for my 02 Z28.
The car has 66,000 miles on the original 10 bolt and doesn't get beaten too hard. Never sees the track. It has a 3 series carrier and is a 4 channel.
The car is an automatic with a 3200 converter and factory 3.23s and makes no noise whatsoever.
I will be doing the install thursday with a buddy. He is a manager at Advanced auto here in my town and it's a block from his house where we are doing the install. As of now I don't plan on replacing anything but the ring, pinion, crush sleeve, gasket, and fluid, however if the bearings are pitted or look bad I like knowing we can run a block over and get them from his shop...I'm just in a pinch financially and can save a good chunk of change not replacing them all.
I plan to follow this guide as much as possible: http://www.pcmforless.com/index.php?...ches&Itemid=56
however, having never messed with a rear end before I am both worried and excited as this will be a learning experience but I really hope I don't **** anything up.
I just wanted to make this thread beforehand and see if there are any newbie mistakes that you might be able to bring to my attention.
And one last thing. Being a 3 series, 4 channel, 3.23 car will I be able to move up to the 3.73s without the paddle kit?
Thanks fellas.
Thanks fellas.
Heres my advice, its worth what you paid for it:
https://ls1tech.com/forums/gears-axles/1550464-advice-those-thinking-doing-their-own-gears.html
https://ls1tech.com/forums/gears-axles/1541712-anyone-care-read-my-paint.html
If you dont have bad *** bearing removal and install tools you will definitely be replacing the inner pinion bearing...probably multiple times.
No need for paddle kit, just grind.
Yeah I hope my notes there help people. I really didnt know what I was getting into and while im reasonably experienced and own a lot of tools there are little tidbits of knowledge that can save you a lot of time.
I think I could do it again much more easily, especially if it wasnt stretched over so much time...it wasnt bad luck, it was just ignorance. Theres really only one way to get rid of that, learn.
Good luck man, youll do fine. Single best info I can give you is to pull the rear and hog out a set of setup pinion bearings. My stock pinion shim wasnt even close.
Having an extra set of pinion bearings so you can hog out the stockers is the best/easiest way ESPECIALLY since this is you first time. You may get lucky but most of the time getting the gears setup requires multiple removals which is a pain in the butt if you are trying to reuse bearings. And, you aren't supposed to reuse the inner (bigger) bearing after removal. It's good practice to replace it.
